Question about Garden
Honda f200 tiller where can I buy a new filter for it ?
Where can I buy a air filter for my Honda f200 tiller
SOURCE: Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
Posted on May 24, 2009
SOURCE: need specs.for Honda rototiller motor
The cam to crankshaft.... the plastic gear has a dot that you can see. mark the tooth with a sharpie so you can see it visible. its a cicle on the cam gear. on the crankshaft the cylinder needs to be at top dead center so when you put it back in all the way to the top. on the gear there is a notch that you line up the tooth on the cam to the two on the crankshaft. Its easier if you take the flywheel off to put it together. Hope I made sense
Posted on Aug 30, 2009
  • 16 Answers
SOURCE: I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: My Honda mini tiller with a GX 31 engine starts
Clutch or transmission, a common problem with FG 100 series Honda.
Posted on Jun 05, 2010
Honda F200 tiller New carb, not getting fuel to engine. while using carb cleaner I can keep it running but dies if I stop feeding it. fuel filter is clean. Tappet brether hose is also off. Help please
The breather hose should pose no issue... but if there is the slightest leak in the fuel hose... it is much easier to pull air than it is to pull fuel... Replace the fuel hose. I only put eBay there to give confidence... Amazon was not responding... Might be beyond the scope of the auto parts house but chain saws, mowers shops... FARM EQUIPMENT should be quite used to these requests Honda Fuel Hose eBay Water Filters Lawn Garden Appliance Parts Honda Tiller Fuel Line
Mar 23, 2016 | Garden
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Oil gushes out of air filter hole.
Oil normally comes out of the air filter area a little bit, but over time, once the oil rings start to wear, more and more oil comes out. So you can either have new oil rings replaced, or you can put in a crank ventillation valve in there and it often helps slow down the oil from entering
May 18, 2010 | Honda Hmantis Mantis Garden Tiller with...
Honda FG100 tiller will not prime, filter replaced
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
Mar 18, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Apr 09, 2009 | Honda Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
