Question about Krups Orchestro Dialog FNF2 Espresso Machine
The water going into the tray
Please can someone tell me how you replace the rubber seal inside the machine
  • 1 more comment
  • Anonymous Apr 03, 2008
    would you how or decribe to me how to chenge the rubber seal?
  • oldwomble Jun 07, 2008
    The coffee is going into the trat sometimes, not always all of it, sometimes about half of it. Can anyone help please.
  • Anonymous Jan 10, 2009
    Is there a diagram or a detail graphic picters of how to change a ring?
Hi There The answer is very simple it is the main seal from the from the press unit which can be changed if you are not handicapped with mechanical things. The O-ring is a red color on with a shore of 50+-5% and for a heat application of around 100 degree Celsius. The dimensions are 38mm ID by 3.55mm diameter. I hope this info was helpful if not u can call 00971506544928 or just e-mail to dietmar2000_2000@yahoo.de and I will guide u through.
Posted on Sep 08, 2007
The rubber seal on my LG WM2016CW has a rip on it and needs to be replaced. The door still seals but water runs out of it. Is there a name for this part or is it just called a rubber seal? How do I...
If the door is sealed water wont run out of the seal? A small rip does not mean it is failed...I am a bit confused but I can tell you that there are also seals in the pump and moter and discharge areas in the BOTTOM of the machine that can fail ... I would need more information to help you further...a reply would be appreciated
Feb 14, 2011 | Washing Machines
A steady stream/trickle of water leaks from tube behind the soap tray and flows out of the spout onto the inner rubber door gasket.. When I plug the tube with my finger, it give a "poof" of...
looks that you have problems with your water valve. make sure the fill hoses screens are clean and valve screen too. check water pressure, you need 20psi or more. if all checks good then replace water valve.
Feb 09, 2011 | Kenmore Washing Machines
Saeco cappacino maker leaking
Hi
If its leaking under the water tank, its this.
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it needs to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won't slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
If its leaking under the machine, its your boiler.
If its leaking into the dredge drawer, its the thiumbscrew in the brew unit, that holds the filter screen in.
If its under your drip tray there is a pocket behind the brew unit that has a cloged drain, just above the center of the drip tray in back.
Jan 07, 2011 | Saeco Vienna Espresso Machine
I have water leaking from seal around door. clothes got twisted inside around rubber part and pulled wire that is supposed to whole rubber in place. i put it back but can not get a good seal. is there a...
hi, the problem is trying to repair it can be hard and there are no guarantees its going to solve the problem, what some people use is silicon you can buy this from most diy stores and then when you put it on the rubber seal keep building it up untill it covers the whole or where it leaks.
Now doing this dosnt mean its going to solve the problem sometimes you can get it just right and then get at least a few months extra use out of it but on the other hand you might still have water leaking as its difficult to create a seal with to seperate materials ie the rubber seal and the silicon plus over time this would fail causing the seal to leak again.
You could try doing it but you may find it wont solve your problem.
What you could do is buy a new door seal you should be able to get one ordered from a local electrical appliance repair shop, but the problem you have is depending on how old the machine is would depend on wether its financially worth spending the money as its its over say 3 years old then the chances are you could soon be replacing motors and belts etc but this all depends on age.
You could try the silicon first as an emergency fix but their is no guarantee that it will last that long so its up to you.
replacing the whole seal would cost the price of the seal plus someone fitting it for you unless you could do this your self.
let me know how you get on or if you need further assistance
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak
open the back of your washing machine, you'll see a series of tubular figure. try to identify on which of the tube correspond to your soap tray, see if the rubber seal is broken or cut into pieces, if it does, then buy a replacement or if you don't have time, try to find an old rubber interior that has been used for vehicle tire, just cut same figure as the your old rubber seal and use it as a replacement
Oct 31, 2009 | Ariston Technologies Washing Machines
Water getting into car
Yes. Sit inside the car and have someone spray the car with a hose. Look and see which rubber seals are leaking. Ford might still sell the rubber.
Oct 27, 2009 | 2000 Mercury Cougar
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
Coffee machine pours water underneath
If its in warrenty send it back.
But it seems like the rubber seal on the inside somewere has been broke or just worn, this keeps the coffee machine preasurized so try replacing this, have a look through your manual it should tell you how to replace this.
Please rate
thanks
Feb 26, 2009 | Saeco Odea Go
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Krups Orchestro Dialog FNF2 Espresso Machine Logo
284 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Ray Murphy
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
