Question about Plumbing
Ferguson frcd1mp3 When I try to play a cd, I get the word NO on the digital screen and it switches off - any suggestions?
  • mary Jul 24, 2013
    sorry - posted this under the wrong section!
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
What is the code for a Ferguson TV
Ferguson tv sky remote codes ' AVForums
www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
Sep 24, 2014 - Hello, does anybody know what the sky remote control codes are for aferguson television. I have tried to find the solution on the internet but the... Sky Remote Code for Ferguson TV
Sep 28, 2014
Sky code for Ferguson Tv
Apr 22, 2010
More results from www.avforums.com
Remote Code For Ferguson TV - Sky - Digital Spy Forums
Dec 15, 2015 | Televison & Video
When switching on the unit and loading a cd it can take a long while to register the cd then it will play for a few seconds then stop. this will clear after a few minutes and play as normal, however if i...
No this is not a common issue. If your traverse assembly is not damaged, then it's possible the loading motor might be the issue.
In either case, I would suggest professional assistance.
Hope this helps.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 18, 2009 | Pioneer CDJ-800MK2 Turntable
CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Mar 05, 2009 | Wurlitzer Jukebox CD Player
MPEG 4 music wont play??
You will most likely have to convert them to regular mp3 or burn the tracks off the cd again into mp3 format. Try right clicking on a track and go to something that should say convert to, and click on it and select mp3.
Feb 07, 2009 | Battery Technology Audio Players &...
Ferguson ftv 28fw1
When we switch on the volume is on the highest level. Any ideas.
Ferguson FTV 28FW1
May 10, 2008 | Televison & Video
Dvd player and 6 disc cd changer for cars
Barry,
Sorry, your problem is not in my field of expertise.
Please ask another Expert.........................T.
Mar 24, 2008 | Car Audio & Video
Cd function not working
you can always try cleaning the lense and if that dosent work exchange it for a new one
Feb 01, 2008 | Jwin JX-CD780 Personal CD Player
Does not switch to Ext Input
You have to enable "Line in" in the Stereo menu. Once you enable it when you press CD/CD-CH it should change to "Line In" and display Line in on the screen. Check the manual on how to enable line in...
Jan 30, 2008 | JVC Sirius KD-LH300 CD Player
Camera not recognised
If you have Windoes XP then you do not need to press any key at all to upload images. If the software on the camera CD is loaded into the computer - remove it. Plug the camera into the computer with the computer running switch the camera on ,ensure you have the upload switch set on the camera Let Windows do the rest
Jan 09, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Plumbing Logo
77 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
