Question about Dishwashers
Lg dishwasher ld 2120h motor running as soon as power switch switched on
As soon as power switch is switched on, motor running, cannot use "delay start" setting but otherwise programs and operates normally. Red warning light with indication shaped like 'S' with arrow at either end is on
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
You must replace control board.
God bless you
Posted on Jul 25, 2013
SOURCE: LG Dishwasher LD12AW2
My LG model LDF7811ST dishwasher fills with water at the bottom of the dishwasher but water does not come out of the spray arms to clean the dishes. The spray arms are not clogged. I don't get any error codes.
Posted on Jun 16, 2008
  • 171 Answers
SOURCE: dishwasher powers up when switched
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
SOURCE: whirlpool dishwasher adp 5966 6th sense delay start problem
you hold in the start button untill it goes off
Posted on Sep 05, 2009
SOURCE: I have a LG LD-14AW2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had a similar thing. Every time I went to start the dishwasher it went "Ding Ding". I could press every button, turn it on and off OK, change cycles etc. I guessed the sound maybe because it thought the door was open, so set to work pulling it apart. This is how I fixed it.
Make sure you do most of this with the power off - there is probably mains voltage inside!
After pulling off the the cover of the door (with the door open, undo about a dozen screws), the front will fall off if you don't hold on to it, and the door swing closed, so be careful. When it has detached, move the metal part aside, and place the "brains" (circuit board etc) on to a chair or similar so the wires don't stretch.
A quick way to see if you have the problem is the same as mine is to remove the orange cable from the PCB as per below:
Turn the power back on, and press the power button, then the play button, things will hopefully work. If they do, turn it off right away and continue as per below to fix. If you are not worried about the safety mechanism - you could just leave it off and put things back together. However if you forget I think the entire kitchen could get very wet!
Reconnect the orange cable, and start by removing the handle. You will need to disconnect the cable block going in to the back of the handle mechanism, and remove the 3 screws as shown:
Once you have the handle off, remove the metal cover. I found I had to slide it down at an angle and back, ie:
With that off, you should then be able to carefully edge out the reed switch - this is the source of the problem. In the image below the arrow point to TWO hooks that need to be released as you slide it out. I found that the hooks got stuck on the seam as well, so go slowly.
Once you have the reed switch out, you can see if the local electronics shop has one the same (probably the best long term fix), or if you pry it apart, I lightly scraped the contacts inside it:
Once this was done, I could put the handle back together and test (I tested before putting the whole front back on). With a screw driver you can put the mechanism back to "close" the door, and things should hopefully work. Or to "open" the door, pull the handle, and use the screw driver to pull it the rest of the way, ie:
Once you are happy it is all working, put everything back together and things should hopefully be away!
Posted on Sep 09, 2009
joe_lishman
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
My LG dishwasher LD-2040WH washed and as soon as the element goes on it switches off by itself. I put it on the gentle cycle and then it switch off and now there is nothing going on it is completely dead...
see the w. diagram for test
1) Test the switch door for defective, this switch can be open or defective and can be open the starting relais and turning off the main motor.
2) Timer: test for defective, clean contact, repair wires loose, broken, or burn.
May 09, 2012 | Whirlpool 24 in. DU940QWD Built-in...
I have LG LD 2040 WH dishwasher, i get an OE error code. I switch the machine on its starts to drain and continues then i get the OE error, the water does pump out so no blockages, i want to replace the...
I traced the fault to one resistor on the controller board and replaced it for R0.10. The original quote to repair was R1480.00! So I saved myself a handsome amount, no thanks to LG!
Aug 11, 2011 | LG Dishwashers
LG 14AT1 Dishwasher not working
Well done! Can you confirm that you own an LG dishwasher?
Thanks!
Mar 14, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LD Dishwasher power problem
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Aug 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher, LD14AT2
the level switch usually a two-or three inch plastic floating device on the base of the dishwasher that looks like a rounded tube. You should be able to pull the top up and down freely otherwise it may be clogged. If you listen closely, you may be able to hear the microswitch inside click as the unit is moved up and down.
Nov 08, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG Diswasher model LD-14AT2
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
Jul 29, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
Owen Barnes
