Aveo cap video is not supporting
  • 100 Answers
Try to reinstall your software driver online.
Posted on Jul 24, 2013
2006 Aveo with antifreeze leak
put it in resovour if theres no cap
May 12, 2013 | 2006 Chevrolet Aveo
Chevy aveo 2008 won't shift out of park
Need to take to dealer has broken shift or broken spring.
May 22, 2012 | Metra 40-cr10 2007-2008 Chevy Aveo Lt Car...
2006 Chevrolet Aveo Check engine light comes on when under 3/4 tank fill it back up and the check engine light shuts off. What could be the problem?
I would first suspect that the gas cap is losing its seal, which happens to take about 1/4 tank of driving perhaps. The fuel tank, like most cars today, works on a closed system with a return and the air above the fuel needs to remain slightly pressurized.
The gas cap was a common problem on the 04 Aveo's; in fact the dealers were fixing them for free then. Tightenning the cap wont imediately turn of the light however because the computer needs to see the engine go through several drive cycle conditions before clearing.
Inpect the cap, the seal and the fuel neck. Perhaps cleaning the cap and seal area if necessary. Look for cracks in the fuel neck. If all looks good and this doesnt work try a new cap either aftermarket or from the dealer.
Jan 02, 2011 | 2006 Chevrolet Aveo
What size are the hubcaps of 2004 chevrolet aveo
CHEVY AVEO USES TIRE SIZE P185/60R14 YOUR VECHICLE USES A 14 INCH HUB CAP.
Nov 18, 2010 | 2004 Chevrolet Aveo
I am trying to find out what the black box with four plugs next to the engine in my 2004 Chevy Aveo is? It is similar to a distributor cap but book says Aveo does not have a distributor cap?
Does it have large wires which go to the spark plugs? If so in a way it is a distributor cap but not in the same way that the old distributor caps worked. It is an electronic distributor of the spark and is triggered electronically instead of mechanically. Less chance for problems and more precise. It also makes it easier to advance spark and do other things which will get you better gas economy. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | 2005 Chevrolet Aveo
Engine light came on steady
Take it somewhere and hook up a scan tool.
Dec 28, 2009 | 2006 Chevrolet Aveo
"check engine light no codes Aveo 2005"
Something that might sound really easy, but please check your gas cap, make sure its on real tight or the rubber seal is still good,if not, get a replacement before you try and get any mechanics to touch your car. It might save your big bucks! All the best and drive safe. Hollywood Harv
Apr 16, 2009 | 2005 Chevrolet Aveo
Engine light
I doubt the gas cap is related to the light, though hopefully you can get a replacement for it because it can be dangerous. As for the check engine light I'm not sure what it could be. Is the car running making noises, does it stall?? If there are no obvious symptoms, you might need to take it to a mechanic so they can read the error message from the cars computer and determine where th eproblem is.
Jul 22, 2008 | 2005 Chevrolet Aveo
Brake drums
Try using a hub puller. I used one with sucess on my 2004 Aveo. The Aveo has studs that are installed in the brake drum (rather than in a hub behind the drum). I used a hub puller with arms that bolted to the wheel studs with a center screw that drives down on the spindle (visible after the drums dust cap is removed). Remove the cap and the spindle nut, install the puller, and a few turns are all that are needed to pop the drum off.
Jun 18, 2008 | 2004 Chevrolet Aveo
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
