Question about GE JVM1651 Microwave Oven
Power SURGE to Amana Microwave
2-day complete power outage due to severe rain/wind/lightning storm with subsequent Power Surge. When Power was restored, Microwave CONTROL PANEL showed no display, no power. Circuit Breaker did NOT trip. Receptacle that unit was plugged into tested fine. Basic visual inspection behind Control Panel shows nothing unusual. Is it even possible that any of the 3 fuses within are designed to protect this Amana Model against a power surge? The same surge killed the digital display on the G.E. Electric Range positioned below it rendering the oven portion inoperable but sparing the stovetop coils which are fully functional (temperature control dials are analog).
MicrowaveSvc
  • 9098 Answers
SOURCE: Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
  • 13433 Answers
SOURCE: Microwave portion malfunction
The fuse in the oven was blown or the main fuse in the house?
Posted on May 24, 2008
  • 108 Answers
SOURCE: Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Posted on Nov 20, 2008
  • 34 Answers
SOURCE: GE Advantium 120 oven: Was boiling water and oven
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Posted on Feb 05, 2010
Testimonial: "That's helpful to know. Found a similar feedback, "is usually a 15 amp Cerramic fuse (white color). Appliance parts places usually carry it.thanks"
kevin_getz
  • 1031 Answers
SOURCE: no power to my microwave GE JVM1750DPBB
You're looking $130.49 for the board.
Posted on May 04, 2012
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 06, 2016 | Samsung Microwave Ovens
Power Surge - GE Microwave
see this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Jul 12, 2013 | Microwave Ovens
I had power outage and now all the number on the timer and thermometar are a mess
The microprocessor has been scrambled due to power surge when it came back on. There is only possible thing you can try, unplug the oven for 30 minutes and plug it back in, this might reset the ic, if not you will need appliance repairman to assess the situation.
Feb 05, 2011 | Thermador MCES MCEB Convection Microwave...
We had a bad power surge during a storm last week which fried my Panasonic NN-T990saf. My question is it worth trying to get it repaired or should I just buy a new micro wave?
Although lightning damage is normally fatal to anything with electronics inside, you might remove the back panel and look for fuse holders. If you find one (minimum) or two (likely), replace them (if you have a cheap multimeter you can check for continuity) and see  if it will turn on. You may have to do a little telephone work to locate the high current fuse which is probably 30 amps.
If you live in an area of frequent lightning strikes, investing in a 'whole house' surge arrester makes sense. These are installed in the main breaker box and any brand I've seen comes with a $10-25,000 insurance policy to replace any dead appliances that fail despite the surge protector. They cost $150-250 US plus installation which you can save if you are afraid to DIY.
Feb 23, 2009 | Panasonic NN-T990SA Microwave Oven
Microwave will not work
Hello Carol95,
I would doubt that the heat generated from the cook surface beneath the micro caused any damage to the micro however the fact that you had a power surge is the more likely culpret. It is possible that a power surge took out an internal component, such as the magnetron, thermal fuse, filament transformer or something else but the cost of a repair call may warrant a replacement MW anyway. Why pay for a service call if all you will learn is that your MW was damaged from that surge? and the cost to repair would exceed the cost to replace.. There are virtually no servicable parts inside the micro that the homeowner should attempt to fix.. If you do not know what you are doing, you can get seriously injured or compromise the RF shield in just gaining access to the inner compartment. You might luck out and learn that the failed component is a simple and inexpesive repair ... so you weigh the risks..
Hope that helps you decide how to approach this..
Regards,
Rick
Feb 16, 2009 | Amana AMV5164 Microwave Oven
Dead
Don't tell anyone that you did not install a surge suppression on it either.
I have a power monitor/surge suppression deivce for it that will keep it from blowing out for $39.00
www.storminprotection.com
Nov 05, 2008 | Danby DMW1146SS Microwave Oven
Microwave-doesn't warm anything anymore
Hello rarms1965... chances are that your microwave was the recipeint of a power surge during the power outage you mentioned.. there is no way of knowing what component took the brunt of a surge and it could very well be your magnetron tube, filament transformer of any number of control logic components.. The problem is that anytime you open the case to check things.. unless you know what to look for or even more so.. what NOT to touch ( High Voltage Capacitor comes to mind) you don't know what you are up against. If it isn't a real expesive model ( you didn't provide a brand or model with your inquiry).. then the cost to diagnose & repair could very well exceed teh cost to replace.. Your call.. but whatever you do.. be sure you KNOW what you are doing..
Good Luck my friend..
Sep 24, 2008 | Microwave Ovens
Seems like electrical storm fried my Advantium??
This is likely caused by a momentary surge from a distant lightning strike.
Take a look at some of these surge arresters:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=%22whole+house%22+surge+protection
Also, your local utility may have them available for lease for a modest fee.
Most of these devices come with an insurance policy that would have replaced your microwave if it had still been damaged.
If I was building homes in our lightning-prone area, I would always suggest the installation of one of these.
Jun 10, 2008 | GE Advantium SCA2001BSS Microwave Oven
Microwave dead after power surge.
A) The fuse you change was the one on top just behind the control board? correct? Not the one on the door hinge side of the microwave. (as is is the Thermal cutout ) Then most likely took out the control board... i would also check the Capacitor and recifier let me know it this helped?
Aug 14, 2007 | Frigidaire PLMV169DC Microwave Oven
GE JVM1651 Microwave Oven Logo
44 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
