Question about Garden
Merry tiller service manual
What type of oil goes in gearcase
3 Suggested Answers
SOURCE: What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Posted on Apr 27, 2009
  • 146 Answers
SOURCE: oil in my tiller
Unless you live in a cold climate, ordinary 30W motor oil is fine. In cold climates, 10W-30 may make starting easier. You don't need expensive synthetic oil. Sounds like you want to take good care of your equipment. Tip: the air filter is a critical component in tillers since they work in dirt constantly. Check it regularly and change it when dirty. That will do the most to prolong the life of the engine. Good luck, and please rate my advice if you find it helpful, thanks!
Posted on Jun 10, 2010
How can we purchase a gear box chain for a Wolseley Merry Tiller, Serial No. T105738?
the chain will be standard construction and can be obtained from any power transmission retailer such as consolidated bearings (CBC) , bearing services or any other bearing retailer
all you will need is the pitch and width of the chain or the old chain as a sample
the pitch is the length of the link and comes in two variations (metric and sae)
one thing to be careful of is the wear of the sprocket teeth.
worn sprockets and new chain will give problems as the amount of wear on the teeth alter the pitch and that will make the chain tend to ride up on the teeth and jump
you may find that sprockets will also be available from the chain supplier
Sep 07, 2016 | Garden
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
Can you buy a service manual for mtd tiller
Every 25 hours change the oil using SAE30 or 10W30 oil. Go online to the manufacturer for service manual.
Aug 18, 2014 | Garden
Atco manual
http://www.allotment-garden.org/rotovator/manuals/Wolseley-Merry-Tiller-Manual.pdf
In the UK the Merry Tiller was produced by the Wolseley company until the 1980s when a change of company policy led to the manufacturing side of the business being sold off to Atco. Over the years the design had changed, making it more expensive to produce. This, coupled with changes of Atco's ownership and increased competition, led to the end of production in the UK.
Jul 09, 2014 | Garden
What oil goes in the gearbox behind the motor , I have a junior
any type of gear oil will work for this. I know some gardners that use tranny fluid for heat
May 04, 2010 | Troy-Bilt Pony Garden Tiller
Model# 110-503110/ Sears Washing machine, Ser.# 4045 Need to know what type and weight of oil to use in the gear box.
From everything I've read, top load, direct drive Whirlpool / Kenmore washers use a 80-90 weight non-detergent gear oil.
Most likely non detergent since some of the parts in the gearcase are plastic.
Following is the Whirlpool service manual for these washers that might help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 27, 2009 | Kenmore Washing Machines
What engine oil do I need for a gasoline Tiller CT2067 - 6.5HP
Find what type engine, go to that engine site, they should have specs.
Mar 27, 2009 | Garden
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
