When the tv gets warm, after about an hour it starts flashing. the flashing does go away after it sits and cools off for 30 min to an hour, but eventually starts up again. We replaced the lamp for it and it worked perfectly for about a week. Then cleaned out the back, removed the dust and again it worked for about a week. dont want to put anymore money into the tv.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
i have seen this problem before and it is either bad capacitors on the inverter boards or on the power supply. these usually have puffed up at the top. replacing these is a good bet. and relativly inexpensive if you can do basic soldering.
Problem is inverter, backlight or PSU. The backlight lamps that illuminate the LCD display are flashing. This creates the "kind of strobe" effect that you see. There are several possible causes for the problem.
The lamps themselves are defective. The lamps do not fire up completely and keep flashing. The lamps are not sold alone but they are part of the LCD display. If the lamps are gone the TV is not worth repairing.
The inverter is the high voltage board that supplies the backlight lamps. If the inverter is defective it can still be replaced. Testing is done reading DC in, checking high voltage out, and using an oscillator to test the phase of the AC out signal generated by the inverter oscillator section.
PSU or main controllers may be defective. This will less common in case of flashing back-light. Test this if the inverter is OK and if the problem is DC voltage input to inverter.
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong: -the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Mine did the same thing. Remove the stand and back of the tv. Be careful with screen do not lay on hard surface and scratch. When you take the back off you will see a board on the left side and a board on the right side. They are labeled slave and master. Remove the ribbon cables and take board out. There are 2 capacitors on each board (about an inch long). These are probably all bad (ends bulged a little with black stuff on bulged end). Radio shack has them for less than $2.00 each. turn the board over and you can read the size of the capacitor. You need someone who can use solder wick and remove all four capacitors and solder in new ones. Notice how the capacitors are turned. Each one is labeled with a dash for negative. Make sure you bend new capacitor connectors the same and put back in the same way. Put the boards back in the tv and attach all ribbon cables. Put back and stand on. hook up your power and cable box and you are ready to watch tv with no more strobe. Me, my husband, and son did ours last week. I looked up the problem on the internet, husband removed stand & back, son with the steady hand did the soldering. Family project that went well for once.
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
I finally hoisted the TV off the wall and took it to the shop because
this TV never "warmed up" such that the flashing went away. $400 later and with
some board replaced... we're back in business.
