Question about Dishwashers
Ariston ll64 Water doesn't drain after wash. How do I fix it?
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Make this test and fix it. God bless you
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2a283ECur
Posted on Jul 25, 2013
4 Suggested Answers
SOURCE: Ariston LL64 error
call 1800 815 589 ariston australia
Posted on Sep 18, 2007
  • 6 Answers
SOURCE: Ariston LL64 doesn't start
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Posted on Jan 14, 2010
caroldon
  • 17130 Answers
SOURCE: Hi, I have an Ariston
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Posted on Aug 03, 2011
Ll64
make this test and fix it. God bless you
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 24, 2013 | Ariston Technologies LL64WNA Built-in...
May tag washer doesn't drain water
the water pump must be brocken you should call in a specialist or try to fix it or you could try to fix it yourself this site might help http://washer-dryer.hubpages.com/hub/washing-machine-not-draining
Feb 01, 2012 | Maytag Washing Machines
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
Hi, I have an Ariston LL64 model dishwasher that doesn't complete a wash cycle. It gets so far and stops with the "crystal care" light flashing. Any ideas? thanks Barry
Aug 03, 2011 | Ariston Technologies LL64WNA Built-in...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Doesn't drain water after rinse
hi to save a little time try clicking onto the wash machine picture at top of post alongside doesn;t drain water ? then the board with with solutions comes up ? go to bottom post ther is a previous post with same symptoms and gives 2x solutions hope this helps if no joy comeback with update feel sure it will be one of these is the problem good luck
Oct 25, 2008 | LG WM-2277HW Front Load Washer
Ariston LL64 error
Jul 06, 2007 | Ariston Technologies LL64WNA Built-in...
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
