Question about DeLonghi PAC C110 Portable Air Conditioner
E2 error My display says E2. None of the buttons are functioning.
4 Suggested Answers
SOURCE: I have a model DE500P
I have not fixed it yet, but I believe that I can. I was told by Delonghi that two of the sensors are bad. The fix is going to cost me enough, & I don't want to pay any more to fix the dehumidifier than I need to. Thank you any way, It is good to know that help is out there if and when needed.
Sincerely.
Rick Bitterman
Posted on Jun 25, 2008
hvac1960
  • 2133 Answers
SOURCE: Unit does not get cold.
E-2 Indoor coil sensor defective. Replace it.
Posted on Jan 04, 2011
hvac1960
  • 2133 Answers
SOURCE: Hi. I have a E2
Indoor coil temp defective. Replace it.
Posted on Feb 07, 2011
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Error message -E2
hi jim just push off button then on button then off again. this will drain off then go to restart mode. hope this helps.
Jan 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Behringer Bass V-Amp
In my xvamp, a strucked microbutton caused E2. I've replaced the button, and everything went right :D
Nov 29, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
DeLonghi PAC C110 Portable Air Conditioner Logo
21 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
