Question about Dishwashers
G 2582 scvi
The dishwasher runs for as few minutes than blips and all the lights are flashing and F78 appears on the dishwaher timer window
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Make this test and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 25, 2013
  • 236 Answers
SOURCE: Lights flashing on dishwasher and not working!
put some towels dowm and tip the d/w over to one side about 45 degrees if water pours out of the base it means that the d/w is in "flood mode" and you have a leak into the base that will need resolving.
Posted on Feb 16, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 8 Answers
SOURCE: Dishwaher not working
hi from italy, well it happened to me and i fixed it yesterday 14 june 2009. the washer pulls the water and then light 2 and 4 blink. check the heating element under the machine. if you ohm this it should show about 100 ohms or less. the maching dies a system check and if it diesn't see the element it goes into alarm. the element will cost about 28 euro. this element if good for the following machine on the box ariston,indesit,hotpoint,scholtes unplug the machine and take it somewhere to work on ,some water will spill out. you will have to replace the clamps once you pry it off. hope this helps ralph
Posted on Jun 14, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
KevinWhite
  • 1902 Answers
SOURCE: Miele model G653 SCVi Plus-3 Dishwasher
Hello & Welcome to FixYa
The first thing that should be checked is the drain hose and the drain pump operation, if the drain hose is clean then check the drain pump, if its not working then replacing it is recommended. Then check the water inlet valve and make sure it is not clogged and the water is coming inside the unit. After cleaning both pump and inlet, unplug the unit and plug it back after 15 minutes so that it works again. Please get back to me if you have any other questions.
Kevin
Posted on Dec 08, 2010
Mains RCD blows after a few minutes of operation
You have a short inside the control unit. When it opens the power protection disengages the unit. It is a warning to get it replaced or face the possibility of a house fire.
Feb 26, 2014 | Miele G 1182 SCVi 24 in Builtin Dishwasher
Miele G863 SCVi All lights blink at the end and it doesn't dry
Check the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
I found that PDF while working on fixing my Miele dishwasher and found it more helpful then most advice on the web.
Dec 30, 2012 | Miele Dishwashers
F78 error - alarm went off dishwasher stopped
hi
after dishwasher take water the red light start to flash and fault f78 is show on the display ( let me now if i am right )
the f78 is the electronic board on the main pump or pump itself is busted
Oct 14, 2012 | Miele G 2872 SCVi 22 in Builtin Dishwasher
Dishwaser problems
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 18, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
My KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Sep 26, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Miele Dishwasher G2170 scvi type hg03 dishwasher problem
Remove and check the "non-return valve" and make sure it's clean. It snaps out and in easily. See page 47 of the manual for this dishwasher.
May 20, 2008 | Miele Advanta G2170SCSF Dishwasher
Dishwashers Logo
173 people viewed this question
Top Dishwashers Experts
Owen Barnes
