Question about Cell Phones
Lg BL 46CN
How to break security pin
Panasonic survelliance cameras - Need to reset
HOWTO: Factory Reset your Panasonic BL-C1/20
www.networkwebcams.co.uk/.../howto-factory-reset-your-panasonic-bl-...
Dec 12, 2007 - Howto guide for resetting Panasonic BL-C1 and BL-C20 back to factory ... CCTV camera icon ... Panasonic BL-C20 Factory Reset Aperture ...
[PDF]Operating Instructions - Panasonic
ftp://ftp.panasonic.com/.../Panasonic/.../security/.../WV-NF284...
Panasonic5. Preface. The network camera WV-NF284 is designed to operate using a PC on a network (10BASE- ... This function detects a motion in a designated surveillance area and issue an alarm signal is ..... Use this button to reset the settings of.
Quick Reference Guide for BL-C230 - Panasonic
Dec 05, 2015 | Panasonic BB-HCM311A Network Camera
How to reset my phone LG BL-44JN
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 13, 2012 | LG Cell Phones
Unlock password for lg bl 42fn
cmo puedo desbloquear mi telefono lg bl-42fn si no agarra mi cuenta gmail
Mar 27, 2012 | LG Cell Phones
WHEN I ON MY MOBILE PHONE IT SAYS ENTER SECURITY CODE IT IS A NOKIA BL-5CT model:3720c-2,Type RM518
Default 6 Digit Security code: 000999 or 1122
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 29, 2011 | Cell Phones
1997 Escort Sdn., airbag light flashes 4 times
Pinpoint Test R: Diagnostic Trouble Code 44 — RH Radiator Primary Crash Front Air Bag Sensor Not Mounted to Vehicle Properly Normal Operation
NOTE: Circuit 618 (BL/W) is grounded to the side of the RH radiator primary crash front air bag sensor case, and the case is grounded through the bracket to the vehicle at its mounting point.
The air bag diagnostic monitor (14B056) measures the resistance between pin 20 (circuit 618 [BL/W]) and pin 3 (circuit 57M [BK]), the air bag diagnostic monitor reference ground. If the air bag diagnostic monitor measures a difference of more than 2.0 ohms between pin 20 and pin 3, it will flash diagnostic trouble code (DTC) 44.
Possible Causes
High resistance on pin 20 (circuit 618 [BL/W]) to ground can be caused by:
  • A poor connection due to loose mounting, dirt, or corrosion at the RH radiator primary crash front air bag sensor bracket mounting location.
  • An open or damaged wire in circuit 618 (BL/W) from pin 20 of the air bag diagnostic monitor connector to the RH radiator primary crash front air bag sensor connector.
  • An open circuit inside the RH radiator primary crash front air bag sensor.
Oct 26, 2009 | 1997 Ford Escort
Security code for LG KS360 PHONE PASSWORD
The Security code pin is 0000 try, it really works promise ! :) :)
May 14, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
How can i break security code phone lock code of lg kg300
the last 4 digits of your cell phone number
Mar 28, 2009 | Cell Phones
How do I get security on my lg vu?
go to the menu then the setting menu then tap more and hit the security menu and a list should appear. at the bottom should change codes and tap that and then security code pin 1 and pin 2 should appear. jjust tap security code and enter the code you want it should set it to that code.
Dec 25, 2008 | LG Vu CU920 Cellular Phone
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Nov 28, 2007 | LG CU400 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
