Can not record or acess recorded list
I have a topfield pvr TRF - 7150 and i have had the message verifying files and folders running across the screen for several days. tried unplugging but its still there. can not access the recorded program list or record a program :(
SOURCE: Refuses to Record Program onto HDD
I have exactly the same problem. The difference with mine is that mine actually starts up - thsn won't shut off until I manually when I set it to record when I'm away.
Posted on Jan 07, 2007
SOURCE: Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
Posted on Mar 20, 2008
  • 919 Answers
SOURCE: Olympus digital recorder WS 110, keeps saying connect to pc
the only thing left to try is to try and format the device and see if you can restore it back to factory default settings. You go to the menu and to the format option. This will permanently remove any recordings you have done and as I said restore the device back to factory settings. If that doesn't work then you will probably need to send it to Olympus for repair service.
Posted on Dec 16, 2008
SOURCE: Transfer of files from recorder to PC
email me steviechan83@gmail.com, if you need help still.
You need to go to the Olympus US site and download the update for vista even though your running Windows XP.
Posted on Feb 03, 2009
  • 13433 Answers
SOURCE: Chkdsk will not run
You need to run chkdsk /F /X and then the drive letter c: for example.
Posted on May 03, 2009
Topfield trf 7150
This indicates your signal from that network is too weak. If your antenna and cabling are OK, you may need a digital signal amplifier.
http://oztoppy.wikidot.com/signalscrambled
To really check this out thoroughly, you need a digital signal strength meter, or a service tech. Ebay has a lot of them
http://www.ebay.com.au/itm/Brand-New-DIGITAL-SF-9505A-Signal-Amplifier-Meter-LCD-Display-Displaying-/271455687566?pt=AU_Television_Accessories&hash=item3f3405138e&_uhb=1
Sep 01, 2014 | Televison & Video
Our Topfield TRF 7180 records ok but pixilates and then keeps skipping when playing back. Can anyone help with is problem or do we just need to replace it? TIA
It may be a fault with the hard disk which does the recording, but I'd check the signal strength to the unit first. You need a good signal for reliable recording, one which does not drop in and out. You should use quad shield coax cable right from the aerial to the back of the Topfield
Aug 30, 2014 | Televison & Video
How to scan channels on topfield pvr
See page 16
Installation > Service Search
It's advisable to do a reset first - Installation >
System Recovery > Reset Service List
Feb 17, 2014 | Televison & Video
The on-screen clock on my sony bravia kdl40w5500 lcd TV (lower RH screen) has disappeared. My problem is that I usually watch TV thru a Topfield TRF7160 PVR and I don't know whether the clock is...
http://www.topfield.co.kr/include/download.asp?dn_dir=1&fname=TRF%2D7160%5FEng%5F09Aug2010%2Epdf
Page 28...on screen display for the clock
Under Front Display make sure it isn't "disabled"
Under sub display you will find the clock and persistence option
Mar 14, 2011 | Televison & Video
How do I delete old recordings off my RCS digital voice recorder?
Press Menu,with the down arrow,scroll down to "folder",press red button. A list of folders will appear.Scroll down to the folder you want, press red button.Now scroll to "file" , push red button.A list of files will appear pick the file you want to delete, push red button.A list will appear with "select" on top, scroll down till you get to "delete" , push red button. A message will ask you are you sure. Use the arrows again to go to "yes" then push the red button again to finalize your delete.
Nov 27, 2010 | Zoom H2 Digital Voice Recorder
I have a Yamaha RX-V667 Receiver and I need a code for the Remote Control to operate my Topfield PVR model 7160 (Australian release). Yamaha have not published any codes for any Topfield products. Do you...
just bought a Topfield trf-2460 PVR and I have got everything working except the remote control (that came with pvr) sound funtion. I can record and playback with the audio working fine but even after setting the TF remote control to work on the TV funtion, it just doesn't like it, except for the mute button, that and the off function. Any suggestions would be appreciated. Joe
Oct 24, 2010 | Televison & Video
How do I transfer files to computer from Olympus VN-3100PC?
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. Browse to the location on your computer where you downloaded and saved the Digital Wave Player files from Step 3
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Nov 29, 2008 | Olympus VN-3100PC Digital Voice Recorder
27 people viewed this question
 Grubhead
Grubhead
