Question about John Lewis JLBIDWS1804 Builtin Dishwasher
John lewis integrated dishwasher
Programme stops midway through wash bleeps 5 times constantly and the display show 60
    Top Expert:
  • John Master
  • 12,223 Answers
Make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Posted on Jul 25, 2013
We have a 3 year old Cooke and Lewis integrated microwave/grill that has recently stopped working. It starts up but after 5/6 seconds it stops and 'err 5'comes up on the display. Any ideas?
if this was purchased from the likes of B&Q, at the time of purchase, the retailer must ensure that the goods are/were fit for purpose for a period of 6 years from date of purchase. This is regardless of manufactures warranty. Take it back, demand a new one, quoting the above
Jan 02, 2016 | Microwave Ovens
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
I have the double drawer dishwasher. It is 3 years old. For about 1 year now one of the programmes - the second one along which is for quite dirty crockery and cutlery (programme is about 99 minutes) -...
A few things you could do.
Is this happening with both drawers.
Take a clean damp cloth and wipe the switches and the inside panel.
Get a couple of Finish dishwasher cleaner kits from the local woolworths/ safeway and run each drawer separately with one kit in each. You will have to select at least the 99 minute cycle.
This should help with having cleaner dishes.
Hope this helps. Please rate the solution if you find it helpful.
Aug 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bleeping constantly, does fill but not wash and turn, 3 hour delay comes on
One of a few problems here, common one is the element has burnt out try replacing however the programmer might be burnt out.
Aug 04, 2010 | Dishwashers
Ignis dishwasher beeps and flashes constantly
salt container is full of water
Mar 10, 2010 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
John Lewis JLBIDWS1804 Builtin Dishwasher Logo
131 people viewed this question
Top John Dishwashers Experts
Are you a John Dishwasher Expert? Answer questions, earn points and help others
