Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
Repair glass cooktop - Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
My glass Whirlpool cooktop cracked. Do I need to buy a whole new cooktop?
No just the glass could be ordered seperatly, the cost of the glass could be as much as $300 for just the glass and unless you plan to replace it yourself it could cost $175 labor for the repair tech to transfer all the parts from old to new glass. So what would be more financially better,to spend up to $500 to repair of 7-900 to replace
Jul 31, 2011 | Cooktops
How to clean glass cooktop maytag electric Model
Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
Joe
May 07, 2010 | Maytag MEC7536WS Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Cracked glass top stove. is it covered under a waranty? it is maybe 4 years old. brought at sears its a whirlpool stove.
whirlpool offers a five year warranty on glass cooktops for thermal damage only not for customer mishaps so call a certified repair place and they can get you a new cooktop if you tell them that it is thermal cracking
Sep 12, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have GE Profile glass cooktop. After cleaning
you can safely use a razor scraper such as you would use to scrape paint. It will not harm the surface and then you can polish it with the cleaner.
Apr 07, 2009 | Kitchen Ranges
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
15 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
