LG WD-M8060TD blinking at the wash and temperature lights
Helpp... my washing machine is blinking after i press the start button at the wash and temperature lights is that DE or soemthing ? need help thanks
SOURCE: washing machine
wont spin
Posted on Dec 08, 2007
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
Dinu_kool
  • 44 Answers
SOURCE: Owners manual for LG, WD 14336ADK
www.asm-service-manual.com/List/LG%20List%20ASM.htm
use the above link to download the owners manual
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
I have LG fuzzy logic 6.5 wf660. When pressing start button ,next time all water level lights are blinking. Machine not working.
See if you can lift the top of your washing machine by unscrewing it from the back and there should be a code and test sheet in there that is very easy to follow.
Jan 01, 2016 | LG Washing Machines
My lg wd-80134t does not spin
Try pressing the "Temp" and "Option" buttons simultaneously for 3 seconds, check if the machine will start, if not unplug the mains supply for a couple of minutes, replug and check whether all the buttons are working and that it will start.
Jun 04, 2015 | LG Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Wiring diagram
can you check the harnest assymble,,,may be its bitten by the rat,,,
Jan 09, 2014 | LG WD-80130F 7.2kg Washing machine
Door mechanism
this is not problem with door swicth ..kindly re main Replaced thE MAIN pcb
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
Lg wd-80130f
sounds like whoever changed the pump has made a hash of the wiring, get them back to it.
Feb 04, 2008 | LG WD-16115FD Front Load Washer
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
