Ihave samsung karishma washing machine timer problem motor not rotating due to it im Electrical enginer want full circuit diagram
2 Suggested Answers
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
BEKO WASHING MACHINE WM5120W WONT START!!!
first off let me say u may have a motor with bad windings. if it is belt drive try removing the belt and see it after plugging in and starting , will it now run? thus weak windings. you may have a bad control board but first check these
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
Washing Machine Repair Help http://www.partselect.com/Repair/Washer/Will-Not-Start
Mar 19, 2017 | Washing Machines
I have samsung washing machine(karishma)semi auto. the problem is not working to drain and spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Washing Machines
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
On start up the washer show F1 Ihave to hit pause start 3 time
The F1 fault is indicating a problem with the main machine control board assembly. It may be going bad but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
Jan 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine problem
Possibly your timer or a motor
Aug 28, 2008 | Kenmore 22422 Top Load Washer
WATER WILL NOT DRAIN OR SPIN
OE is inded a drainage error.
From what you describe it is most likely that the drain motor is not working properly due to a loose electrical connection or bad motor itself. This is not that easy to verify since it requires some machine moving and disassembly to get at it.
I can give you further instructions if you like...
If your machine is still under warranty you should call someone in for service.
Aug 06, 2008 | LG WM1815CS Front Load Washer
My maytag washer just stopped working...
Manually open the timer switch component rotate the knob forward and it will work. / rotate inline w/water fill full keep near the timer you can hear the timer running or not / if not the small motor of timer need to replace availqble in appliance service center,.
Dec 16, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine won't spin
From http://www.diyfaq.org.uk/electrical/washing_machine_faq.htm
Why won't my washer spin? There are several reasons for this fault. First a washer will not spin if there is water in the tub. If this is the case, then check “Why won't my washer empty?”. Even though the washer might have emptied the water, the machine might be misled into 'thinking' there is still water left in the machine due to a blocked pressure barrel (see “My washer is leaking, why?”). If the belt has become detached or loose, the drum will not spin, nor will it spin if you have a faulty motor, module or timer. Usually a motor will have carbon brushes which slowly wear away. There needs to be enough material left to touch the commutator and have enough spring left in them to make sure there is a good contact. If the brushes in the motor are OK then you need to check the circuit across the terminals on the motor, because there is a thermal overload switch inside which may have tripped. Should the motor be OK, or be the type that doesn't have brushes (induction), then the chances are you need to test the speed control module. This is a circuit board that directly controls the speed of the motor. It may be found on or near the timer, or sometimes at the base of the machine, and usually requires specialist equipment to determine its worthiness.
Dec 12, 2007 | Washing Machines
Maytag washing machine
When the washer fills up, first thing that actuates is the diaphragm switch under the control header. This is directly connected into the timer. The diaphragm switch starts the timer motor listed on the diagram as TM. Check the timer motor. If its working you can see something rotating in a little window on the motor. The motor operates all the internal cam switches.
Apr 16, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
