192168 1 1 - Computers & Internet
192168 01 login
Pam- Have you connected directly via ether net cable when attempting to connect to that IP?
Jul 29, 2014 | Motorola Computers & Internet
192168 01 admin password
Press reset button and hold it for 30 seconds to reset device to factory default.
To connect to the router, launch your web browser and go to 192.168.0.1
Login ID is then "admin" and no password is required.
Jul 13, 2014 | Computers & Internet
First SSID(Service Set IDentifier) is what Identifies your WLAN network. When you add a router, you establish a WLAN. Each item you connect to your router must use the same SSID. You will be asked to make a unique network name, when you set up your router. This will be the SSID of your network. If you go online for you router menu, you should be able to find that information in you configuration menu. NOT to be confused with the IP address of your computer.
Dec 29, 2013 | Linksys Wireless-G WRT54G Router
Connect to 192168 01
Click on Start(Windows button) > Run > type cmd and press enter. Type ipconfig and press enter. Make note of the default gateway address. Open a web browser and type this address in. Configure away.
Dec 14, 2013 | Computers & Internet
Connect to 192168 21
You either need to provide a lot more information or call your internet service provider.
Dec 01, 2013 | Computers & Internet
192168 11 login
connect your router to the computer with a straight through cable.go to your web browser and enter the default ip address of your router.
enter default password and enter setup screen.
contact me incase of any deficulty anywhere.
Nov 04, 2013 | Computers & Internet
Don't understand how to set password. please help
Plug the router into the power socket and configure you own machine to obtain IP address automatically. Load up Internet explorer and type in http:/192168.xxx.xxx which is the local address of your router. You should then get a password screen. Enter default user name and password and it will take you to the configuration screen. The full IP address and user name and password are dependant on which model you have. See list below From there you need to read the instructions very carefully and match it with the information provided by your ISP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
? Q: What is the default IP address, username, and password for routers? ? A
ZSR0104
192.168.8.1
Administrator password: admin
ZSR0104M
192.168.1.1
Login password: No Password
ZSR0104B
192.168.1.1
User Name: admin
Password: 0000
ZSR0104AS-01
192.168.8.1
Administrator password: No password
ZSR0104E
192.168.2.1
ZSR0104CP (Grey color)
192.168.1.1
User Name: admin
Password: admin
ZSR0104CP-05 (Blue color)
192.168.10.1
User Name: guest
Password: guest
ZSR0104WE-01
192.168.2.1
ZSR0104WE-04
192.168.2.1
User Name: admin
Password: 1234
ZSR0104WE-05
192.168.1.254
User Name: admin
Password: 1234
ZSR1104WE
192.168.2.1
User Name: Empty
Password: Empty
ZSR0104DE
192.168.2.1
ZSR0104FS
192.168.1.1
User Name: admin
Password: admin
ZSR0104UP
192.168.1.1
User Name: admin
Password: 0000
Dec 22, 2010 | Zonet Computers & Internet
Can't get login asus wl-520gu page when i type in http 192168
Try using http://192.168.0.1 to get to the log in page of your router. The username should be: admin and password is either: admin or (no password). If this does not work, there is a reset button located on the back of your router, press this button and hold it for about 10 seconds while the unit is on, then try going to that address again.
If this still does not work, look on the bottom of your router or on the box which your router came in or the manual that came with the router. Check that you are trying to go to the correct IP Address. It should be located on the router itself, although, the standard IP Address for most routers is 192.168.0.1
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Aug 19, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
