Toshiba lcd model 40bv702b led flashing red&green
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
  • 187 Answers
SOURCE: Stuck in standby.
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
Posted on May 27, 2009
  • 17 Answers
SOURCE: red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
Posted on Oct 08, 2009
  • 8457 Answers
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
Posted on Jan 27, 2010
welcomejee
  • 10594 Answers
SOURCE: Toshiba Regza 42RV535U 42 in.
TV needs back light inverter board replacement as discussed in chat session, required board is available with shopjimmy.com
Thanks.
Posted on Jan 25, 2011
Hello, I have Toshiba TV Model #47L7500U. When I turn it on the TOSHIBA (red) logo comes on for a several seconds, then screen goes black. Green LED on front continually flashes green. No pic or sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 26, 2017 | Toshiba Televison & Video
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
Sky code for toshiba 40bv702b please
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls.See it in "Mosaic" view.It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Feb 19, 2014 | Televison & Video
No sound on my toshiba 40bv702b tv
Hi
Its a common problem it seems with this tv but easy to fix!
Press menu on your controller and go to install and tune!
scroll down and select re-installation and re-tune!
This will restore your sound!!
Hope this helps.
Oct 22, 2012 | Toshiba 40BV702B 40 inch full hd lcd tv...
Model GW611 the first and second last led flashes. fills up and wont go into wash cycle
If by first led you mean green to the left & amber to the right then that is fault code (130) & i think it is (Rotor Position Sensor) If you meant first to the right that would be red & green, code 65.no that doesn't sound right.its 130 & im sure thats rotor sensor.
May 25, 2010 | Fisher and Paykel Washing Machines
LED goes from red to green then back to red, when
led goes from red to green and back to red when turning tv on
Dec 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
Don't want turn on and the power light flash red ,green
The LED flashes means that the set is in protection, Until unless the problem not removes the protection system keep activate,
First you have to check power supply unit, Check it properly if you have service manual then first check fuse, if fuse is burnt then replace it and if not then proceed check all the capacitors especially main capacitor, check STR also.
The above said components must help and solve the problem,
Thanks for using fixya.
Jul 01, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
