Question about Computer, Chip, Cruise Control for Dodge Avenger R/T Sedan
07 pathfinder cruise control stop working
If you have no factory diagnostic manuals,
you will need a repair shop that has that, in
the form of a computer data base
Posted on Jul 24, 2013
07 pilot cruise control doesnt work, light does not come on. Any suggestions?
Yes , your cruise control is computer controlled , your best bet .take it to the dealer . Nothing you can do .
Nov 27, 2017 | Cars & Trucks
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
2010 Nissan Pathfinder Cruise Control issues
First I'll assume you haven't read the owners Manuel, Cruise control is not perfect on any vehicle. if coming to a hill put foot on gas to help rpm, going down hill put foot on brake to keep same speed, cruise control operates off of engine vacuum. Speed sensors can be affected by putting on smaller or bigger tires than what is on drivers door.
May 24, 2017 | 2010 Nissan Pathfinder
The cruise control light comes on but it does not engage. It's a 1995 pathfinder.
If your light comes on but the cruise control does not engage you may have a vacuum leak some where. When you set your cruise control your vehicle uses vacuum to maintain speed and if you have a vacuum leak this can not happen. Try checking all of your vacuum lines. I hope this helps.
Aug 26, 2011 | 1995 Nissan Pathfinder
Why did the cruise control stopped working after i got my transmition repaired
Transmission shop overlooked hooking up cruise cable when they changed your trans.
Mar 25, 2011 | 1998 Nissan Pathfinder
Cruis control does not work
07 sebring cruise light comes on but cruise does not work i have installed a new clock spring and now the horn works but no cruise control.
Jun 16, 2010 | 2007 Chrysler Sebring Sedan
Speedometer, Odometer, Trip Odometer stopped working
yes the transmission speed sensor has most likely failed, to confirm this have a trouble code test run
Jul 05, 2009 | 1996 Nissan Pathfinder
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
