Dab receiver fv
No sound at digital modus, fm works well
  • Audio Player... Master
  • 5,259 Answers
Digital signals require better aerials than FM radio, a wire can pick up FM signals, but Digital won't pick up a thing.
Posted on Jul 29, 2013
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
HOW DO I GET MY CDAB5IR STEREO DABRADIO TO WORK
The first thing is to consider what DAB signal quality you have there. It might not be strong enough. Digital radio is not like AM/FM, it simply goes off altogether if the signal is weak.
I would take it to the shop and ask for assistance, or get next to a DAB radio which does work well. Then recheck things like settings, tuning, and a good battery in it (I think that model is a smallish radio?)
Nov 04, 2013 | Audio Players & Recorders
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
NO SOUND FROM DIGITAL TUNER
Hi Guys, I have been doing some research on this problem and found that during manufacture of the Cambridge Audio DAB range that they had used substandard voltage regulators in these units. I have repaired a number of theses all with similar faults and every time replacing the 5v voltage regulators with LM340T5s and capacitor upgrade from 2200uf 16v to 4700uf 16v this will solve all the problems.
Nov 28, 2009 | Cambridge Audio Azur 640T Receiver
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
60 people viewed this question
 Grubhead
Grubhead
