Question about Zebra S4M Thermal Label Printer
S4m zebra printer produce noise
My zebra pinter s4m produce noise when printing
  • 9 Answers
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Posted on Jan 27, 2009
Madbigwhoper
  • 13 Answers
SOURCE: there is error "bblock"
BBlock is BOOT Block. The printer is not booting up the settings completely. Probably got corrupted. You will need to download the bootblock version for this printer & upload it via either USB or LPT1 port. You should contact Zebra so they can direct you to the proper Zebra site for the download & instructions. The process of the upload is no more that 15-20 minutes.
Zebra phone # is 847-913-2259 I think option 2 is tech support. be sure to have s# of printer & tell them you need to find the boot block & installation info for the S4M. Good luck.
Posted on Feb 11, 2009
jwr1914
  • 31 Answers
SOURCE: Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Posted on May 27, 2009
seltzercool
  • 21 Answers
SOURCE: my zebra printer s4m is saying ALERT CLEARED HEAD
Alert Head Open will show everytime u open the Head , when u close back the head it will show Alert CLeared Head Open, then it's normal.
Ribbon Out Show means the printer doesn't detect a ribbon, make sure there's nothing wrong with ribbon installation. if everything fine, then the problem is you Ribbon Sensor. u can try to adjust the sensor with a screwdriver ( - ), make a little bit higher
Posted on Aug 20, 2009
bartech9
  • 155 Answers
SOURCE: How to print to zebra s4m 203dpi using vb6 and usb
You can generate the ZPL code in a text file and send it to a generic printer connected to USB.
Roberto Martinez
Posted on Oct 06, 2009
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
Is it possible to import data from excel into the labelprinter Zebra S4M?
You can print a text from XL, but you owuld have to use a page set up that is the same as the label size, through a Zebra or Seagull driver.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
