Question about Home
Saniflo float Hi macerator runs on works OK with sink and shower water flush toilet runs on and on stops when tapped on side.how do we fix thanks
    Master:
  • 966 Answers
Check flushing mechanism at the bottom to ensure nothing blocks it and that it closes securely after flush.
Posted on Jul 30, 2013
  • 145 Answers
SOURCE: Saniflo Sanitop pump keeps running
CHECK YOUR OWNER BOOK
Posted on Dec 12, 2008
kachbibi1
  • 979 Answers
SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: shower does not empty
Did you try to plunger the shower drain?
Posted on Feb 12, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
citroenchris
  • 600 Answers
SOURCE: Our Saniflo - Saniplus works fine and efficiently
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Posted on Mar 18, 2010
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
74 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
