Question about Propellerhead Graphics Publishing, Design & Multimedia Software
Application error with Reason 3.0
When I open Reason 3.0, I recieve an error msg that states: "Failed to open GUI support library. Application can not run." I tried uninstalling the software and reinstaling it but it still happens. I use this software all the time and it has been on my comp for 6 months.
SOURCE: error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Posted on Jan 12, 2009
SOURCE: Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Posted on Feb 26, 2009
SOURCE: My Sony Vegas Movie Studio 8.0 was working
I was having this issue also, with Vegas 8.0a and DVDA 5.0. Found an answer that worked for me on another forum. I think I unstalled Visual Basic C++ 2005 Redistributable when I uninstalled an audio-networking program. Here is the link that fixed it:
<a href=''></a>
Once I reinstalled this, I didn't even need to reboot. Vegas & DVDA were able to start immediately.
Posted on Dec 28, 2009
  • 561 Answers
SOURCE: getting apple application support error 2
1. Uninstall iTunes.
2. Download and install WinRAR.
3. Download and Right-click the iTunesSetup.exe icon and choose "Open with WinRAR".
4. Once the EXE is opened in WinRAR, double-click AppleApplicationSupport.msi and when the installer window is open choose "Repair".
Posted on Jan 12, 2010
  • 68 Answers
SOURCE: I have bought and installed Nero Multimedia 10.
Try creating a super admin account. In command promt type this command: net user administrator /active:yes ......restart the pc after that. Then log in with the super admin account and try installing and running nero. Hope it will work.
Posted on Feb 17, 2011
  • 525 Answers
SOURCE: installed a new hard drive
You have to have the original software to reinstall a program. Just tranferring the files does not work. By default windows must complete the setup process through windows installer.
Posted on Mar 15, 2011
Testimonial: "thanks for the solution!"
0 characters
1 Points
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
Apr 22, 2013 | Adobe Acrobat 7.0 Professional
ITunes Error 13010 - How to correct this error in iTunes
As with any application in any operating system in this high tech computer industry today, there is always going to an error of some kind. How that error can be eliminated, is always the principal concern of any computer user of a Mac or PC.
One of the errors I would like to provide a tip for you, on how to resolve, is the "Error 13010" error message, which affects users of iTunes in Mac OS X.
The Error 13010 alert, will usually appear when a user is unable to launch and open iTunes. More often than not, however, the fix for this error is a relatively easy one.
Here are steps for you can implement to eliminate this error:
For Mac OS X
• Make sure iTunes application is closed.
• Click anywhere on the blank space of your desktop and Finder will appear near the Apple menu icon located in the upper left corner of your screen.
• From the Finder menu click on Go> then select Go to Folder
• You will need to type /Users/td7/Music/iTunes in the open dialog
• This will take you directly to your iTunes folder.
• Within iTunes folder, locate and remove to the Trash,
the iTunes Library Genius.itdb. file
Once you have removed this file, close the Finder window and relaunch
Launching iTunes will restore a new iTunes Library Genius.itdb file
and as a result, no longer see the Error 13010 alert message.
In the event that this procedure does not allow you to launch iTunes normally, you should remove iTunes and re-install the application.
But don't worry though, you will not lose your iTunes Library, as that remains untouched in the Music folder.
You are simply going into your Applications folder and removing iTunes application and then reinstalling it.
Here is the link for downloading and re-installing iTunes, as needed:
Download iTunes '09 for Mac
So now you have at least one workaround, from a number of iTunes errors, should it manifest, which you can use to resume normal functionality of your iTunes application.
I will be providing more tips in future articles covering workarounds like this, for the various error codes which can affect the functionality of either the Mac OS X platform or any applications installed within its volume.
As always, I hope this information proves beneficial to you in some way, if not now, in the future, should such an error like this adversely affects your iTunes application.
Thanks for reviewing this Mac OS X Fixya Tip.
on Apr 09, 2010 | Apple iTunes
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.
Go to the Click here for the Link to Download Acrobat
Download the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
Apr 16, 2013 | Adobe Acrobat 7.0 Professional
Installed a new hard drive with windows 7. Hallmark card studio was installed on an external hard drive. I don not have the installation disk, it is in storage in another state. when i click on...
Mar 14, 2011 | Sierra Hallmark Card Studio Deluxe 2004...
I am trying to open up iTunes, I get the following error message: the iTunes application could not be opened. An unkown error has occurred [13014]. Thanks
Close itunes, and go into windows explorer.
Get rid of the file named iTunes Library 8 Genius.itdb
You can always rebuild Genius results after you get itunes running properly again.
Jul 03, 2010 | Apple iTunes
ProPix won't open, I get the error message"Failed to initialize Audio Library". Thai never happened before, please help Bob
Your application's "audio library" may contain one/some corrupted files or some files are missing or have been deleted recently by mistake. Your first option is to restore your system to the previous state when it was working. If this doesn't help, run a full system virus scan using an updated antivirus and reinstall/repair the program.
I would also suggest you to do a clean install after possible backup of the library.
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Zio Corporation CameraMate ProPix OnTV for...
Iiriver 3 failed to start SMV.dll was not found
Search google for smv.dll. A lot of people have this problem and apparently the manufacturer says you need to remove the current version completely and then download the latest version which fixes the problem from the manufacturer's website.
May 02, 2010 | Dell Graphics Publishing, Design &...
Corel x2 problem: Unable to Load Library when sharing to VCD
Hey everyone, I faced the exact same, excruciatingly frustrating problem. After a quick search, I found forum threads telling me that when Corel Video Studio was modified to suit Vista, something about its 3D transitions got messed up.
So, if you face this problem while using Corel Video Studio on Vista, check that you have removed all 3D video transitions and try rendering again.
Jan 27, 2009 | Corel Paint Shop Pro Photo X2
library/application support/rewire -  system access needs to be read/write   also reason will only run from with in applications folder not desktop etc......
Aug 26, 2008 | Propellerhead Reason 3.0 (991010004) for...
Graphics Publishing, Design & Multimedia Software Logo
78 people viewed this question
Top Propellerhead Graphics Publishing, Design & Multimedia Software Experts
Are you a Propellerhead Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
