Question about Air Tools & Compressors
2E8 ingersoll rand
How much oil to use and what type ?
  • 54 Answers
SOURCE: I have a Ingersoll Rand P185 WJD air compressor
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Posted on Nov 19, 2009
  • 2309 Answers
SOURCE: what type of oil do you use for this compressor
1962?? if memoryserves me right the call for a 30w oil non detergent
Posted on Apr 21, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 214 Answers
SOURCE: Ingersoll rand compressor type 30
It sounds like the pressure switch is bad or out of adjustment. Typically the pressure switch is set at 175psi on a 2340. If the auxillary valve you are speaking of is on the pressure switch and is constantly blowing air from it you have a bad receiver tank check valve. Also if you are getting a lot of oil out the valve at the pressure switch you may have some oil control rings bad.
Posted on Feb 10, 2011
  • 257 Answers
SOURCE: We have Ingersoll Rand Type
Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
Posted on Mar 07, 2011
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
How much oil for 2420N5
the price of t30 select is 6,000.00 pesos.
May 26, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Where can I get an oil fill drain plug for ingersoll rand compressor 2340L5-V?
There are alot of resources to obtain this. I would search the net or you can contact ingersoll. the 800 # on the unit would be a good place to start.
Jan 29, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
WHAT TYPE OF OIL CAN I USE IN MY TYPE 30 COMPRESSOR
I am sure Ingersoll Rand would like you to use there all season select synthetic oil, or you can use a good quality R+O 100 oil, also known as SAE30 non detergent. do not use cheap oil for gas engines,,, buy a good name brand from a regular oil distributor, and specify yo are using it for an air compressor. and most manufactures will recommend you change it every 3 months.
Jan 08, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
Air Tools & Compressors Logo
207 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
