Question about Mustang Seats MUSTANG SC-P80D43 Matte White 80" 4:3 Portable Free Standing Projector
Projection screen won't retract
Screen won't retract into case. I may have pulled it out too far...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pulled out the Holman hose out too far..now won't retract at all...hubby is going to kill me!
yeh i pulled mine out too far now wife wants to kill me!!
anyway opened it up and spring was broken!!
Apr 13, 2013 | Kitchen Appliances - Others
Screen won't adjust from blue
if the screen has lines in it the Blue CRT is at fault and will need replacement. You can get replacement Blue CRT for that model from www.tvrepairworld.com
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
CRT fluid for Philips 60PL92000D
  • dEAR sIR:
    Turn on the TV set, bring up the convergence menu and make sure the three colors--red, green and blue--converge and overlap at the cross in the center of the screen. This is needed to help converge the TV later. Turn off and unplug the TV.
  • 2
    Remove the front screen by popping off the bezel and pulling the three combined screens out. Place wide cellophane tape around the frame to prevent the three screens from separating. Lay the screen someplace where it won't be bent or scratched.
  • 3
    Remove the circuit board from the bottom of the CRT neck. It may be held in place by one screw or glued in place with silicon. Pull it out without twisting it.
  • 4
    Disconnect the large red wire from the high voltage transformer by grasping it with a large side cutter and rocking it from side to side to lift up the fastener. Disconnect the two bundles of wires from the main circuit board and leave them hanging from the CRT.
  • 5
    Remove the ground connectors by releasing their tabs with a narrow screwdriver.
  • 6
    Remove the CRT assembly from the TV by removing its four flat-bladed screws and pulling it out of the TV. Lay the CRT down with its filler plug facing up in a location far away from the TV's circuit boards.
    sincerely. God bless you
    ernesto cuaddra
    managua, nicaragua
  • Feb 15, 2012 | Philips 60PP9202 60" Rear Projection...
    Just bought a MadCatz Dreamcast Light Gun - no matter what I try it won't calibrate, just flashes on the screen when the trigger is pulled. Any thoughts ?
    The gun could be broken. However, if you're trying to use it on a flat-screen TV (LCD, Plasma, or Rear-Projection), those TVs are not compatible with light guns. You must use an old-style CRT TV.
    Jul 13, 2011 | Mad Catz Video Game Consoles & Games
    Seat belt won't retract complete, drivers side
    have a look to see if its coiled in twisted as you pull the belt out if the buckle doesn't line straight to the female end well its probely retracted in twisted to repair pull the belt out all the way and then realign the belt its quite hard to do so take your time hope this helps.
    Jun 03, 2011 | 1998 Saab 900
    I pulled the screen down all the way and am not able to release it to make it go back up. It seems to be stuck.
    csbala,
    In most cases when the screen is pulled too far you can get it to release by giving a quick tug and releasing it quickly. It could take several tries to get it to retract but it should. Remember to give it a sharp, quick tug, more like a snap and release.
    Thanks for using FixYa and for the great rating.
    hardrocko
    Mar 06, 2011 | GrandView Elegant Pull Down Screen...
    Da Lite projector screen will not retract. It is pulled all the way down
    After pulling the screen down to the desire length, The mechanism will lock itself once you stop pulling.
    To retract it, you need to pull the cord down again and allow the screen to retract on its own. The screen will retract rapidly at first but will slow down to a gentle stop when it reaches the case.
    Try it.
    Jan 30, 2011 | Da-Lite Model B with CSR(Controlled Screen...
    I have a grandview elegant electric projection screen and when I retract it, it stops about a foot below the case and won't retract entirely into the casing. Help please.
    Electric screens are just about the same as a garage door opener. They have a up and down limit setting. Usually screens will have the motor on the left as you look at the sceen, this is where the limit switch ajustment screws are. If they are labeled great, if not hopefully they are obvious to see on the motor or roller. Hope this helps.
    Aug 05, 2009 | GrandView Elegant Electric Plug-In Screen...
    Mustang Seats MUSTANG SC-P80D43 Matte White 80" 4:3 Portable Free Standing Projector Logo
    85 people viewed this question
    Top Mustang Seats Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Mustang Seats Office Equipment and Supply Expert? Answer questions, earn points and help others
