I accidentally plugged my logitech z623 in 220v current when the Max intake was 120v. It immediately stopped working. Can it be fixed?
2 Suggested Answers
SOURCE: Blown Subwoofer
did you manage to fix this problem ... i am afraid i might have made the same mistake. But I used a 220V-110V adapter that I have been using for the notebook. I dont understand why that doesnt work in the case of the speaker. Is there any way I can make it work again?
Posted on Jul 14, 2007
I Accidentally plugged my 125v sewing machine into an 230v outlet
None. "Accidentally" forced the plug into where it did not fit? Next time, ask a nearby 5 year old if they would do that: if the answer is, "YES." Then, do not do it. You just dead shorted 240VAC in your sewing machine= 120v L1 120V Neutral
Jul 25, 2016 | Singer 6160 Sewing Machine
Accidentally using US 120V electrical appliance in Singapore without using an electrical converter
If you are in Singapore you may be advised to buy a cheep for the time being and wen you get back home take it in to get it fixed with your waranty.
Jan 27, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
Voltage change to 120V
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Jul 14, 2013 | Morphy Richards Accents 44744 4 Slice...
We have a lioghtolier 600 volt dimmer switch talking to an HAI OmniPro and it stopped working. It has two other switches nearby and they work fine. The problem switch has no blue LED on when the light is...
Recycle the the dimmer switch and replace it with a new one. The dimmer switch was probably rated at 600 Watts. Therefore, 600 Watts/120 Volt which you house voltage equals= 5 amperes.
5 amps is the maximum current for the dimmer switch.
That means the voltage is 120V/240V with max current 5amp/2 1/2 amp. The HAI OminPro is drawing to much current and it's exceeding the the current limits of the dimmer switch.
Get a new dimmer switch that maximum current of 15 amps with 120 volt house voltage. That will fix you problem. GB....stewbison
Aug 22, 2011 | Lightolier Controls Easyset Dimmer...
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
120v plugged into 220v outlet
Thata agood question maybe the motor and maybe a lot more like the water valve. the agitate and spin selonids and the timer. Cant say cause some of them may noy be out.
May 10, 2009 | Washing Machines
X230 logitech not working.
i did the same to mine,
just replace the power transformer with one that accepts 110-240 volts
easy to do, but check cost might be better to buy a new set depends on your situation
Aug 20, 2008 | Logitech X-230 Computer Speakers
Blown Subwoofer
Hi , you will have to open the box and check for any fuses along the power input line, replace them if any and try it out but i strongly believe what happened there is that you fried the power supply in your subwoofer , there is no easy fix to this , you will need to replace the transformer and possibly check to see if the rectification circuit is damaged too, and the amplifier too. Good luck
Mar 21, 2007 | Logitech X-230 Computer Speakers
106 people viewed this question
 Grubhead
Grubhead
