Question about Mustang Seats MUSTANG SC-P80D43 Matte White 80" 4:3 Portable Free Standing Projector
Screen won't retract
I think I may have pulled the screen out too far, and now I can't get it to retract into the case. Can you help? Thanks.
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pulled out the Holman hose out too far..now won't retract at all...hubby is going to kill me!
yeh i pulled mine out too far now wife wants to kill me!!
anyway opened it up and spring was broken!!
Apr 13, 2013 | Kitchen Appliances - Others
My Child Pad won't come on. My dad thinks it's something to do with the screen but I'm not so sure. Why won't it come on and how can I fix it?
I think I may be able to help you. So the same prob;e came with my childpad. Just remember as long as it does not work have the password with you. Because my works now but I forgot the password. So I opened the back blue thing. And then I figured that the charging thing was to loose. So, I just have to make it so that the charger won't come out, so some how my dad make it tighter. But I think that might be the problem with yours as well. If you have a solution to my problem (forgot password) please email me at hinazaheer1@gmaill.com Thanks!! And I hope it helped in some way :)
Mar 03, 2013 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
After using a pokemon cheat on No$gba, part of my screen is red and it won't stop flickering
Try re-installing windows, I have seen in some cases where this fixed the problem.
Jun 26, 2012 | Dell Inspiron 6400 (883585945283) PC...
Vaio VGN-NR31S Nvidea 8400M Graphics Problem
that 'flexing' the case puts tension on the ribbon cable that connects the motherboard with the screen. replacing that video component(up under keyboard top) will do the trick
cpu is far removed physically from this issue
May 22, 2012 | Sony VAIO Notebook
Seat belt won't retract complete, drivers side
have a look to see if its coiled in twisted as you pull the belt out if the buckle doesn't line straight to the female end well its probely retracted in twisted to repair pull the belt out all the way and then realign the belt its quite hard to do so take your time hope this helps.
Jun 03, 2011 | 1998 Saab 900
I have a dell XPS M1330 and its screen is loose. For e.g. if I am in a car / bus using my laptop, the screen tends to fall backward or forward. How can I tighten the screen?
I would try to look around the screen and see if there is any screws to tighten. Just try a few screwdrivers, and gently tighten the screws, with ought pulling to hard. If they are too tight, the laptop won't close. Don't be too invasive, if you have to take anything beyond the battery case off, you can screw up and destroy you hard-earned laptop.
Hope this helps!
May 27, 2011 | Dell XPS M1330 Notebook
I pulled the screen down all the way and am not able to release it to make it go back up. It seems to be stuck.
csbala,
In most cases when the screen is pulled too far you can get it to release by giving a quick tug and releasing it quickly. It could take several tries to get it to retract but it should. Remember to give it a sharp, quick tug, more like a snap and release.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 06, 2011 | GrandView Elegant Pull Down Screen...
Da Lite projector screen will not retract. It is pulled all the way down
After pulling the screen down to the desire length, The mechanism will lock itself once you stop pulling.
To retract it, you need to pull the cord down again and allow the screen to retract on its own. The screen will retract rapidly at first but will slow down to a gentle stop when it reaches the case.
Try it.
Jan 30, 2011 | Da-Lite Model B with CSR(Controlled Screen...
I have a grandview elegant electric projection screen and when I retract it, it stops about a foot below the case and won't retract entirely into the casing. Help please.
Electric screens are just about the same as a garage door opener. They have a up and down limit setting. Usually screens will have the motor on the left as you look at the sceen, this is where the limit switch ajustment screws are. If they are labeled great, if not hopefully they are obvious to see on the motor or roller. Hope this helps.
Aug 05, 2009 | GrandView Elegant Electric Plug-In Screen...
Mustang Seats MUSTANG SC-P80D43 Matte White 80" 4:3 Portable Free Standing Projector Logo
89 people viewed this question
Top Mustang Seats Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mustang Seats Office Equipment and Supply Expert? Answer questions, earn points and help others
