Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
Caller ID My phone didn't come with any paperwork. I can't program the caller ID. I need a manual and can't find one on line. This is frustrating. Everything should have paperwork!!! Can someone help me?
  • 6 more comments
  • too_sweet Nov 16, 2007
    same problem.No instructions and cannot get screen working.............help.phome connected to fone line using one connector,and ring is ok, dial out isk,but nothing I can get to stay on screen.music is ok when pressing hold......can anyone help meplease.
    regards.Van
  • Billhilly Nov 28, 2007
    I do not have a dial tone the speaker phone works but when i pick up the headset no dial tone
    Is there not a phone number you can call to talk to anyone!
  • Dunzel Jan 06, 2008
    Looking for the Manual on how to setup this Innovage Speaker\Caller ID* LCD Touch Panel 12 Digit Calculator.
    Does anyone know where I can find one?
  • Anonymous Feb 13, 2008
    no guide to your product the talking callerID LCD Touch-Panel Phone
  • LJKCSR42 Mar 07, 2008
  • flyingdoctor May 06, 2008
    Hello, I can't set up the caller ID and the list of incoming calls doesn't exsist. I have the manual but nothing in there relates to the caller ID which works fine on my other 2 phones of a different brand. Regards, Vern
  • Anonymous Mar 26, 2014
    The phone company says caller ID is working from their end, but does not show on the display. Any ideas?
  • 4 Answers
Have you found a manual yet!
Gary (hubbahubba)
Posted on Jan 28, 2008
Check the Batterys on the bottom of the phone, they may be missing or need replace, thats could be the biggest reason why the phone is malfuncitoning
Posted on Jan 01, 2008
  • David Sisk
    David Sisk Jan 01, 2008
I have had this PDA for a while and fiind it came without the directions,so I have plugged lt in and answers great and reply is plain no static,but screen I cannot add anything.I am willing to buy a manual.Help please........cheers Vanessa
Posted on Nov 16, 2007
  • too_sweet Jan 04, 2008
    thanks for all the help it is appreciated.think the telephone is a lemon...as after talking for a while it shuts down.still havent worked out the ID or screen,but will soldier on as do not like being defeated.................................no way.thanks all and Happy New Year to you all.............Vanessa.
SOURCE:
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Phone doesn't show caller id numbers anymore.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
http://www.retrevo.com/support/Sony-IT-M602-Telephones-manual/id/751bh629/t/2/
Mar 10, 2010 | Sony IT M602 Corded Phone
Caller id
Yes, u need to program all the caller information into the phone. Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
Aug 04, 2009 | Panasonic KX-T7633 Corded Phone
How do you set up caller ID on a Norstar M7208 phone with 4 lines?
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Jul 23, 2009 | NorStar M7208 Corded Phone
CALLER ID
Do you still have a problem?
Aug 11, 2008 | AT&T Partner 18 Phone (315805B)
Caller ID
press feature 811 then touch the ringing line and it will display the caler info.
Mar 14, 2008 | NorStar T7316E Corded Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller id
Unfortunately just adding caller ID to your phone line will not work with many business phone systems, especially older systems.
You can have this phone on one of several different Toshiba phone systems. The system must have caller ID equipment installed and programmed correctly for caller ID information to be shown on your phone's display.
Caller ID information is transmitted between the first and second ring. With business phone systems the system itself needs to collect this information and then pass it along to any phones that are programmed to ring at any given time.
Oct 26, 2007 | Toshiba DKT-2010 Corded Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
128 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
