Question about Kenwood KDC-8021 CD Player
Kenwood kdc 8021.display/panel
When I'm taking off the keys display will should closed itself...it's closing-but after 3-4 seconds it's coming back to previous position...what shall I do??
  • Anonymous Nov 13, 2007
    I took the facia out and the panel closed, now I cant get it open again to put it back in again
No clues mate bu5t i get the same problem if u doi eventually find out could u let me no?? also if u no where i could get a user manual 4 it that would b a big help mines ex display model cheers mate... oggy
Posted on Sep 17, 2007
  • nate  hoggins
    nate hoggins Sep 22, 2007
    If the display does not light up, the buttons do not function correctly, fascia not staying shut or if the stereo appears as if it is totally dead, then the cause is probably down to a failure of the FPC which will need to be replaced.
    As a quick diagnostic check, press the reset button or remove the power plug for a few seconds, refit it again, and see if any motors start whirring away in the background, or if the fascia rotates, if they do, chances are the FPC is indeed faulty, and if the unit remains quiet and dead, then something a little more serious may be at fault. hope this can b of some use 4 u mate still lookin 4 copys of the user manual if u no where i can get them??
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
KDC-716S sometimes plays CD, other times just tray drop
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 01, 2009 | Kenwood KDC-716S CD Player
Display disappeared on kdc 8021
If you mean that the rotating cover has flipped back round covering up the control panel turn on the ignition and push the top left of the panel. this should make the cover flip back around and make the interface available.
Jan 12, 2009 | Kenwood KDC-8021 CD Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
My Kenwood KDC-7024 has just started playing up - as soon as you turn on the ignition, the face panel comes down, flicks on for all of 2 - 3 seconds and then closes, it then keeps doing this repeatedly...
It's possible the flexible PCB (more of a cable, really) that connects the faceplate to the main unit has cracks in the conductors. This has been an issue with some of the older Kenwood HUs that have the MASK motorized faceplate. The flex-cable gets bent and pinched enough over the years that it eventually cracks the copper.
Mar 07, 2008 | Kenwood KDC-7024 CD Player
Kenwood kdc-x859 just stopped working
This hapened to me also. I removed the power fuse to the radio and it reset itself.
This solved the problem for me.
Feb 28, 2008 | Kenwood KDC-X859 CD Player
Smashed screen
simple, you have to change it.search for a dealer near about you. or buy a used flatface.
Sep 17, 2007 | Kenwood KDC-8021 CD Player
Kenwood KDC-8021 CD Player Logo
202 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
