Question about JVC EM37T - 37 LCD 60Hz 1080P
Mounting bolt size for jvc 37 in - JVC EM37T - 37 LCD 60Hz 1080P
What is the size of the 4 mounting bolts on the Sharp Aquos LC-37D43U?
To know more about this, you have to download its repair manual. Its disassemble section will have all details.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Sep 16, 2014 | Sharp AQUOS LC-37D43U 37" LCD TV...
JLC37BC3000
best way is to call whoever made the set for length, thread type and number of bolts.
May 14, 2012 | Toshiba 37AV502U 37 in. LCD HDTV
NEED BOLT SIZE TO MOUNT 42 JVC LCD 120HZ PLEASE
Best way is to Call JVC customer service with the model number--need number of bolts,thread type and you are going to find in almost all cases they are standard ones---Home Depot will have them.
Apr 26, 2012 | JVC 42 in. LCD TV
2003 Kia RIO WHEN TURNED TO ON CAR starts and the starter will not stop turning
Replace the starter.
Removal & Installation
1.5L & 1.6L (VIN 5) Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the 4 upper intake manifold stay bracket bolts.
  4. Disconnect the starter electrical connections.
  5. Remove the upper starter bolts.
  6. Remove the lower starter mounting bolt(s) and the starter.
    Fig. Starter mounting-1.5L and 1.6L engines
To install:
  1. Install the starter.
  2. Install the lower starter bolt and tighten to 27-38 ft. lbs. (37-52 Nm).
  3. Connect the starter electrical connections.
  4. Install the intake manifold support bracket and finger-tighten the 3 mounting bolts. Tighten the lower bolt to 27-38 ft. lbs. (37-52 Nm).
  5. Install the 4 upper intake manifold stay bracket bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  6. Install the upper starter bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  7. Connect the negative battery cable.
1.6L (VIN 3) Engine
  2. Remove or disconnect the following:
    Negative battery cable Air intake assembly Shift cable and bracket Starter electrical connections Starter
To install:
  1. Install or connect the following:
    Starter Starter electrical connections Shift cable Air intake assembly Negative battery cable
May 04, 2011 | Kia Rio Cars & Trucks
What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
Mar 21, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I need to know the head bolt torque on 99 gmc 2500 with 6.0 engine
The cylinder head gasket displacement can be verified by markings visible on the top side of the left gasket locating tab. Some 4.8/5.3L head gaskets may have 53 stamped onto the locating tab. Some 6.0L head gaskets may have 60 stamped onto the locating tab.
  1. Install the alternator mounting bracket using the four bolts. Tighten the mounting bracket to the cylinder head bolts to 50 Nm (37 ft. lbs.).
  2. Tighten the bolt at the rear of the power steering pump. Tighten the bolt to 50 Nm (37 ft. lbs.).
Hope helps.
Jan 30, 2011 | Chevrolet C2500 Cars & Trucks
Alternator replace
NOTE There is a trend among manufacturers today to refer to the source of belt-driven electrical power as a -generator-; however, by virtue of the method in which the -generator- produces electrical current the device is actually an -alternator-. The two terms may be used interchangeably.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    Negative battery cable Accessory drive belt Alternator upper mounting bolt Engine splash shield Radiator support access panel Rear alternator bracket from the engine Alternator mounting bolts Duct on the back of the alternator Electrical connectors Front alternator-to-A/C bracket Alternator
To install:
    Alternator Front alternator-to-A/C bracket. Torque the bolt to 37 ft. lbs. (50 Nm). Electrical connectors. Torque the battery connection nut to 115 inch lbs. (13 Nm). Duct on the back of the alternator Alternator mounting bolts. Torque the bolts to 37 ft. lbs. (50 Nm). Upper front bolt. Torque the bolt to 35 ft. lbs. (47 Nm). Rear bracket to the engine. Torque the bolt to 37 ft. lbs. (50 Nm). Radiator support access panel Engine splash shield Accessory drive belt Negative battery cable
  2. Refill the cooling system. 4 DeVille
  3. Before servicing the vehicle, refer to the Precautions Section.
  4. Drain the cooling system.
  5. Remove or disconnect the following:
    Negative battery cable Accessory drive belt Radiator Electrical connectors Alternator mounting bolts Alternator
To install:
    Alternator Alternator mounting bolts. Torque the bolts to 37 ft. lbs. (50 Nm). Electrical connectors. Torque the battery connection nut to 111 inch lbs. (12 Nm). Radiator Accessory drive belt Negative battery cable
Dec 30, 2010 | 2004 Cadillac Deville
Need mounting bolts
lg company or go to hardware store and get the biggest bolts that will fit in the holes. Otherwise you may be able to purchase them on ebay.
Jul 09, 2009 | LG 37LC7D 37 in. LCD HDTV
I broke timing belt when replacing hormonic balancer
Here are some. Hope it helps =D
Timing Marks
Diagram
TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
A/C Compressor Bracket Bolt 37 (50)
Alternator Bracket Adjuster Bolt 16 (22)
Alternator Bracket Bolt 33 (45)
Balance Shaft Pulley Bolt 22 (30)
Camshaft Pulley Bolt
2.2L DOHC 37 (51)
2.2L SOHC & 2.3L 27 (37)
Crankshaft Pulley Bolt 184 (250)
Power Steering Belt Adjuster Nut 11 (15)
Power Steering Pump Bracket Bolt 33 (45)
Power Steering Pump Mounting Bolt 16 (22)
Shift Cable Bracket Bolt 16 (22)
Timing Belt Tension Adjuster 33 (45)
INCH Lbs. (N.m)
Timing Belt Cover Bolt 108 (12)
Valve Cover Nut 90 (10)
Water Pump Bolt 108 (12)
Jun 28, 2009 | 1992 Honda Accord
Where/what do I buy to mount my tv on the wall?
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
Mar 27, 2009 | Dynex DX-LCD37 TV
JVC EM37T - 37 LCD 60Hz 1080P Logo
69 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
