Question about Westinghouse WST2000 IntelliBLEND Work Top Blender
Westinghouse WST2000 IntelliBlend
I plugged in my blender the power light comes on when I press it. Also all the button lights come on when I prees them. The problem is the blender does not work. What am I not doing right or is there a mal function? I cannot find my manual and this is the first time I am using the blender.
  • 1 more comment
  • jaminn57 Mar 08, 2008
    I have the same problem. The computer portion of the blender works and all the light come on the switches but the motor does not work.
  • Anonymous Mar 23, 2008
    yep all my lights come on but the blender won't go. is it a motor problem u think??
  • Anonymous Mar 24, 2008
I have had my blender sitting for over a year ( only used it once ) because of the same problem and asked my husband to take a look at it... he opened it ... cut the zip ties took the metal banding off ( note only one side of the motor has the metal banding). What you need to get at is behind the first (I think) resistor. Behind that is a thermal fuse (found at radio shack part # 270-1320 about $1.96). you will need some kind of tester to check the ohms going through it (should read zero) the bad one on mine read 334 ohms and you will need a soldering iron to put it back together. Actually a good project for someone who loves to tinker with this.
Posted on Jun 29, 2008
I need a blade for Lectrix blender Model 0101
get to the shop where you bought this blender and ask for a blade.... they mite take for exchange....
good luck Thanks for rating
Jan 04, 2011 | Westinghouse 0101 IntelliBLEND¿ Work...
I need glass jar for westinghouseintelliblend model#wst2019w thanks
sometimes you can post what you are looking for on Ebay and wait ,there are companies that have new and used for Demos very cheap too >^.^<
Mar 12, 2010 | Westinghouse 0101 IntelliBLEND¿ Work...
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Westinghouse inteliblender
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a warranty...it might just be easier to buy a new blender.
Sep 27, 2008 | Westinghouse 0101 IntelliBLEND¿ Work...
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Blender is not doing anything
either the motor is inoperable, or is improperly wired. return it to the retailer. that is assuming you have the cup firmly seated before you try to operate the machine.also if the control panel has more than one speed make certain that only one button, or switch position is engaged
Westinghouse WST2000 IntelliBLEND Work Top Blender Logo
265 people viewed this question
Top Westinghouse Blenders Experts
eyecam
ray gallant
Tom Chichester
Are you a Westinghouse Blender Expert? Answer questions, earn points and help others
