PTCL AN1020-25 broadband router
Sir i have my cctv camera with DVR installed. i want to view the camera online using my ptcl router AN1020-25. i assigned static ip to my dvr 192.168.1.15 my router control panel ip is 192.168.1.1 how i can forward port or any other setting required for my ptcl router. regards Ali
3 Suggested Answers
  • 58 Answers
SOURCE: Port forwarding on dlink adsl2 router
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2.
Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4
. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a.
If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6.
Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
Posted on Jun 21, 2009
  • 23 Answers
SOURCE: port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Posted on Apr 19, 2010
Pls help me step by step how to online viewing from my cctv
You need to provide us with more info. Your dvr broadcasts on an iPhone address with a port number. Both of these are needed. Then the bbrand of router you have is also needed
Nov 24, 2014 | ECHO1USA 4ch H.264 Standalone Dvr 204e...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I need ptcl phone lock code 0572520171
Lock Unlock PTCL Code For Mobile & International Calls If you would like to stop making Mobile & International calling from your PTCL do following steps
  1. First call PTCL help line 1236 and ask them to open lock facility(it will take 24 - 48 hrs).
  2. Once facility is available you can lock phone by dialing *33*1234*4# (replace 1234 with your desired password).
  3. To unlock phone dial #33*1234# (Replace 1234 with your password).
By doing this i lock my PTCL mobile & international dialing.
Nov 05, 2010 | Cell Phones
I am in pakistan which is best net speed i want 2GB speed which is best dsl is best or not and what is it monthly charges
HI buddy,
based on my research on the Pakistani ISPs the best one is PTCL.
these links will help you in understanding the features ,advantages and tariff of the plans
http://www.zaheerspeaks.com/2009/01/22/ptcl-wireless-broadband-on-the-go-lauched/
Tariff:
http://www.zaheerspeaks.com/2009/03/07/ptcl-annouces-new-on-net-tariff-one-on-net-rate/
This will surely solve your issue!!!
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
May 14, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I want to connect intrnet on my vwireless set but facing the problem of Error691 that password and user name not valid as domain. I set user name as vwireless@ptcl.com and pass word as ptcl.i am reporting...
your problem is about authentication.
you must never forget your username and password
there are lots of way to solve this situation
what do you use to do this?
what modem,phone line,wireless device are you using and dont forget about your account username and account password?
Apr 30, 2009 | Computers & Internet
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
CCTV-DVR
Have you given this computer Permission for you to remote connect, let me know?
Aloha
Bob
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
452 people viewed this question
David Payne
David Payne
