Question about Health & Beauty
Elexus power wheelchair
The charger is not working? I think it's the battery but how do I get to the battery?
3 Suggested Answers
  • 692 Answers
SOURCE: I purchased a Pronto 41 wheelchair and a Winsunny
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
Posted on May 30, 2011
badfish6686
  • 563 Answers
SOURCE: Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Posted on Apr 21, 2013
Testimonial: "Took the batteries back to Batteries Plus and had them tests. Load test was good but the capacity test showed batteries should be replaced. Replaced batteries but chair drives slower then it did with the bad batteries....barely moves when on low setting. "
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
The battery charger is not working.
I too had a problem with my chair not charging. I found out that my on board charger is bad. It's very costly to replace. However, I found a work around. I bought a off board charger from amazon for 13.94. It's listed as: 24V 2A Scooter battery Charger with XLR connector.It plugs in under the joystick. It solved my problem. Good luck.
Brian
May 04, 2012 | Jet 3 Ultra Power Chair
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
My battery on my power chair will not take a charge
Then its time to replace the batteries unless you think your charger is not working correctly. Now if the batteries are really low in voltage then the charger cannot pick them up. To charge anything below 17 volts will not be charged by your charger Hope this helps
Feb 19, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Wheelchair charger blinks in green despite connecting all the cord. What is wrong
Charger is charging should turn solid green when fully charged if not the batteries are bad or charger is not working correctly
Aug 05, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
Apr 12, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
