Question about Dehumidifiers
Drain pan location in Kenmore Elite 251.90701 dehumidifier
The dehumidifier leaks from the bottom, it was suggested to clean or clear the drain pan. Another suggestion was to have dehumidifier on a level service. This dehumidifier and other Kenmore's were used only in the basement. This elite purchased March 2013 leaks on the bottom.
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
MNTECH
  • 1543 Answers
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Posted on Sep 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
SOURCE: Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
Posted on Apr 29, 2009
Dehumidifier leaks all over the floor, bucket is installed correctly and is not cracked
Check the drain pan. It is what collects the water from the condensor fins and funnels it to the bucket. Over time, dirt in the air contaminates the pan and builds up as a gunk which eventually blocks the flow.
Expect to need a towel or two to clean up. Often the drain pan needs to be removed by unscrewing it from the motor or disassembling the entire dehumidifier... hopefully, yours is one of the easier ones with a pull out slot. While you're cleaning the gunk, also check the fins to make sure they didn't get fouled and the hose to make sure it's clear as the same thing often happens there
Nov 29, 2017 | Dehumidifiers
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
Dehumidifier leaks
One open, other closed.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jan 16, 2014 | Kenmore Dehumidifiers
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
Water will not drain into reservoir. Instead the water drains/leaks onto the floor.
First, is the unit level? Tipped a bit to one side or the other, or front to back could be the issue.
Next, is the drain hole clear? locate where the water drip from into the bucket and push a wire up there to ensure it is clear. use something like a garbage bag tie.
Oct 13, 2010 | Kenmore 54501 Dehumidifier
Our machine is collecting water but I have a drip coming from the bottom onto the floor? It is coming from the behind the collection area?
This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
Sep 28, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
My dehumifier is leaking. The collector pan is fine. I took the covers off and could not detect anything. It is pretty simple...air blows by the coils, condenses, collects and runs into the pan. Looks...
TRY IT ON LOW FAN SPEED AND SEE IF IT LEAKS , MAKE SURE IF THERE IS A HOSE OR SMALL DRAIN PAN UNDER COIL   THAT IT IS CLEAN AND FREE OF DIRT .SOMETIMES ON HIGH WATER IS BLOWN PAST DRAIN PAN AND DRIPS ON FLOOR , THIS MAY BE A BAD DESIGN. IF THERE IS A FILTER CLEAN IT
Apr 20, 2010 | Maytag M7DH45B2A Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
Dehumidifiers Logo
73 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
