Question about Samsung DMT400RHS Builtin Dishwasher
Low water level - Samsung DMT400RHS Builtin Dishwasher
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Posted on Aug 15, 2013
  • 5 more comments
  • Donald Miller
    Donald Miller Aug 15, 2013
    For some reason the link did was removed. The link ishttps://picasaweb.google.com/11705435319...
  • scott hovanec Aug 24, 2013
    i must thank you. our dishwasher has been down since March, and since it was out of warranty, i was hesitant to call for repair. i figured I've nothing to lose by tearing it apart. it wasn't as dirty as i expected, but it seemed to work! its running thru a cleaning cycle now without shutting off.
    i spoke too soon. it almost made it thru the cycle. looks like i gotta make a call now.
  • Donald Miller
    Donald Miller Aug 27, 2013
    Scott my dishwasher would start, cycle water out, fill, cycle water out, then flash the 3 LEDs (Normal+Heavy+Smart Auto). All of that took say 3-4 minutes. It failed every time (it was intermittent for several weeks).
  • phmaddnes
    phmaddnes Sep 17, 2014
    My level sensor looked like it was a biology experiment. Thanks for the pics.
  • lpanella Sep 27, 2014
    Thanks for the tips. I've just cleaned it out, although it was not terribly dirty. I have turned it on and the lights come on, but so far no water flow into the machine. I'm not sure if it's having to recalibrate or what. I'll give it some time to "reboot," but I think I may be buying a new case sensor unit.
  • jeff darnell
    jeff darnell Mar 10, 2015
    Donald- thank you. Although the parts weren't dirty i cleaned them out with gallons of hot water. It works now. maybe it was a loose connection as well.
What does it mean when water level is low
It means that there is a bad water switch on the water fill sensor or stop
Aug 22, 2015 | Hobart CL44E-8 - Left To Right 30-kW...
Dolphin Dishwasher, Why do they have a low water level sensor on the wash tank for, since the water level always over that level.
This sensor is there to warn you in the event the water level is too low to properly clean the dishes
Sep 19, 2010 | Dishwashers
What is E no 1 on washing machine wa13G7Q1
Hi
Error code 1E means WATER PRESSURE SWITCH ERROR. This error occurs when the Generated Frequency Signal of water level is low or high.
WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the Water level is detected as low or high for more than 5 seconds, then it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 minutes after which you would get this error. To resolve this issue you can try and clean the filter screens inside the water lines. To check this disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back. This will resolve the issue.
Daniel
Sep 01, 2010 | Samsung Washing Machines
Water level to low on boiler
There is a automatic valve that is suppose to open when water gets low in the system. They do rust up and quit working. You can add water to the system. There should be a waterline making a loop around the automatic valve. It will have a manual valve open this up to allow the water through and close it again when the correct water pressure/level is acheived. Should replace the automatic valve as soon as possible. I hope this has helped, please rate if it has helped in any way. Good Luck and have a great weekend.
Apr 02, 2010 | Water Heaters
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Why is water level always low ?
how low? do you have a water level switch? post model number
Apr 07, 2009 | Washing Machines
Whirlpool Duet GHW9400 Water Level Seems Too Low
Scott,
Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
Apr 03, 2009 | Whirlpool GHW9400 Duet Washer
Neptune water level
ck drain hose level ..end should be 30-36 inches from floor also be sure hose fits loosely in standpipe ..possible water is siphoning out after fill up since these are low water use machines any drop in water level can cause problems
Sep 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Samsung DMT400RHS Builtin Dishwasher Logo
1,172 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
