The volume sing with red x and said no audio output divice is installer
Red X just means device is disabled. In order to enable the device click on the "+" on that particular device then right click on the device itself...then click on properties..look at the "device usage" box and click it to enable your device. that should be it..
Rate this solution
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you need more help with this post a reply
hope this helps
