Question about Dell 1700n Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
I have tore the thing apart, its clean and nothing is out of the ordinary. It got a paper jam the other day, i cleaned it out and now ever since then the paper jam light wont go away. Any ideas on what could be the problem?
  • 20 Answers
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Posted on Aug 29, 2007
Had the same issue with the "Paper Jam" light blinking... but no paper jam. Turned the printer off then back on and the light went out.
Posted on Sep 05, 2007
I am getting the paper jam light, I have looked everywhere and there is no paper jam. Is there another item that would cause the sensor to read jam. What can I do to fix?
I have a brother and have had paper jams I couldn't find before. Try pulling out the toner cartridge. It could be inside of that area where you can't see it from the regular openings.
Mar 21, 2011 | Dell 1700n Laser Printer
When printing i get the paper jam message have checked for paper jam but dont see anything
Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
Sep 29, 2010 | Dell 1700n Laser Printer
I've cleared to paper jam. Paper was not torn so
you have take the ink cantainer out and disconect the printer for one min then reconnect
May 27, 2010 | Dell 1700n Laser Printer
My dell 1700 says that there is a paper jam but there is no paper jam visible
You must remove all drums & toner and open all doors and look with a flash light. steven 818-888-0006
Apr 26, 2010 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Paper Jam error
Try feeding paper from the front, if it works, your paper pickup rollers maybe having problems (dusty/worn-out).
- Bianca
Jun 19, 2008 | Dell 1720dn Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
604 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
