Question about Gigabyte Computers & Internet
Fault indicators for GA-965P-S3 push start button and only the fans start and the CPU fan stops and the auto restarts endlessly What is diagnosis
What are the fault indicators and meaning (or where do I get them from) for diagnosis of this for GA-965P-S3, push start button and only the fans start and the CPU fan stops and the auto restarts endlessly What is diagnosis
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Gigabyte Master
  • 2,226 Answers
Need the right heatsink fan on cpu
Posted on May 21, 2014
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
nenalex2002
  • 134 Answers
SOURCE: ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Posted on Mar 28, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Posted on Feb 20, 2010
SOURCE: ga-h55m-s2h board not booting, nothing on screen .
Just had the same problem, same board. This mb does not play well with all types of RAM. I had a single 2gb Patriot dimm and it did the exact same thing, removed the RAM and it would boot but no screen. Replaced the single dimm with 2 - 1gb dimms and it booted right up with no problem. Hope this helps.
Posted on Mar 12, 2010
  • 1267 Answers
SOURCE: what cpu is compatible with motherboard GIGABYTE
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
Posted on Dec 02, 2010
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
Jul 08, 2015 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
What cpu is compatible with motherboard GIGABYTE GA-965P-DS3
Dec 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
My motherboard GA-8GGEM800 no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
my motherboard 945gs no display and cpu fan continus restarted .I have try with new cpu & ram. promblem not solve
Oct 28, 2010 | Intel Motherboard
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Hi my mother board is working but after 5 mintues it turn's off why its got 2.00gig of ram and anew power supply please help. Thank-You John
1. make sure that all motherboard fans are working especially the CPU fan. the motherboard shutsdown when it reaches a max temperature.
2. maybe your power supply is defective.
3. make sure that the CPU heatsink is properly seated in the processor
Jun 24, 2010 | Gigabyte GA-965P-DS3 (0818313003027)...
I just flashed my Bios Gigabyte GA-965P-DS3 from F12 to F13. Now my CPU fan is at full speed. It's loud and driving me nuts. I've looked all through the bios to see if I can slow it down. Also, went on...
it's actually good that your cpu fan is runing at it's full speed. Usually only the manufacturer issues firmwares. Lookforward Gigabyte for the update. thanx
Jan 20, 2009 | Computers & Internet
Comp will not restart
Unplug unit, press power button , plug in, power up.
if it still will not power up .
see that the fan at least jiggles ,saying its trying to startup.
Mar 08, 2008 | Zalman Tech (ZM460B-APS) 460-Watt Power...
CPU fan
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Feb 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
System and Processor fans don't spin- anything else is working
Your description indicates your power supply may be faulty or there is a break somewhere in the 24 pin main ATX cable wiring.
Swap out the power supply. Make sure your PSU has a 24 pin ATX connector & (not a 20) pin & a 4 pin ATX_12v connector for the CPU.
Feb 17, 2008 | Gigabyte GA-M61P-S3 Motherboard
New system not booting
Check in the BIOS that your RAM and / or CPU speeds are correct or put them on auto. Choose Default BIOS settings first.
Aug 03, 2007 | Gigabyte GA-M61P-S3 Motherboard
Computers & Internet Logo
95 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
