Question about Sony Sa-wsis10 Sawsis10 Sub Woofer For Dav-is10 Davis10 Other
Rewiring SAWSIS10 for use with an AV Receiver
I have purchased an AV receiver, and wish to use the Sony SAWSIS10 Subwoofer. However, it uses a proprietary connection from the Sony DAV-IS10 unit. I want to connect the subwoofer on an Onkyo TX-SR313. I believe I can use a Right/Left connection or a Standard RCA jack. I prefer the latter. However, I am not sure how I might go about this! PLEASE HELP!!!
yeroc
  • 397 Answers
SOURCE: no sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Posted on Jan 20, 2008
Digital Pigg
  • 8 Answers
SOURCE: Subwoofer
You have the subwoofer plugged into ac and you see a light? parhaps the RCA cord is bad. Try another one.
Posted on Aug 02, 2008
dunnbiker
  • 8546 Answers
SOURCE: Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Posted on Dec 29, 2009
kerguney
  • 577 Answers
SOURCE: Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Posted on Jan 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
Is it possible to disconnect this subwoofer from the rest of its system and use as a stand alone connected to a new amp/av receiver?
This should actually be pretty easy: whatever signal you are feeding to your new amp needs to go to the old amp through its aux line-level input (a "Y" cable would be fine). The old amp has the filter built-in to send only the low frequencies to the sub. Let me know if it doesn't work via the link.
May 07, 2014 | Sony Sa-wsis10 Sawsis10 Sub Woofer For...
How to install/wire an RCA jack in Sony SA-WSIS10 Powered Subwoofer?
This link will allow you to download the manual for this system ... from there you may be able to figure out the solution or take it to an electronics expert for further advice.
Jul 24, 2013 | Sony Sa-wsis10 Sawsis10 Sub Woofer For...
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Feb 07, 2010 | Sony STR-DE597 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Jan 10, 2008 | Sony SA-W305 Subwoofer
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
No sound coming from subwoofer
Oct 25, 2007 | Sony STR-DG510 Receiver
Sony Sa-wsis10 Sawsis10 Sub Woofer For Dav-is10 Davis10 Other Logo
97 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
