Question about Kicker (ZX750.1) Car Audio Amplifier
Kicker zx700.5 amp rem wire turns on protection light
My amp was working fine til today and i checked all the wires none of them turn the protection light on but the rem wire does it turns the protection light red and my sub box wokt work. what should i do?
Garfunkel01
  • 56 Answers
SOURCE: Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Posted on Aug 15, 2007
  • 631 Answers
SOURCE: Protection light won't stop blinking/ Subs don't work
The amp probably has shorted output transistors to eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Oct 07, 2008
SOURCE: speakers cut off when bass goes up...
you may be running 2 low of ohm load
Posted on Feb 14, 2009
  • 14 Answers
SOURCE: i think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Posted on May 01, 2009
  • 3 Answers
SOURCE: Kicker 750.1 Amp wont play music
The wire you are needing to check is the Blue antenna wire that runs from the back of your deck to the amp. More than likely if you are getting a green light on the amp than that means this wire blew a fuse somewhere or blew the amp itself. I would say re-check all the fuses. (there should be one in front of battery wire and some on the amp) If these are still good and you are still getting green light but no sub than check the wiring for the box. I just had to re-wire my box because one of the cables came loose in the box. I have a Kicker 750.1 and a kicker 12" L7 so i understand what you mean... it just takes time and understanding. If everything fails and still it wont work.. than hook the amp up to a friends car and see the results.
Posted on Sep 09, 2010
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
I have a 300 Watt dual amplifier connected to one 12" kicker dvc sub at 2 ohms. Every time the volume is turned up the protect light turns on. I had 2 of these kickers wired to a Rockford amp a week...
Then you have found your problem. It's internal on the amp. Protection circuitry issue. Have it Benched at a shop with the same impedance you are running it at. If it benches ok, check your ground, it should be no longer than 18" and go directly to the floor frame, not a seat bolt. You should also be running at least
4ga power as well. Hope this helps.
Jan 11, 2011 | Dual 300W Class AB Bridgeable 2-Channel...
Everything is work....except the amplifier..It didn't turn on..and my car missing a turn on wire..i didn't turn very loud before it broken.
there is a blue/white wire at the back of your radio you need to use that and run a wire to the rem on the amp
Aug 13, 2010 | Kicker ZX1500.1 Car Audio Amplifier
Protection light comes on. what is it and how do i fix it
Wire connection is not right or the power source is not enough. Make sure the radio wires connected to the car are correct and that the usually blue and white REM wire from the radio is connected to the REM position in amp. Power source must be straight from battery not from anywhere else. Ground wire should be connected any metal bolt in trunk or to a new hole drilled into frame. Also make sure that the wires for speakers are running on 1 side of the car and the power is on the other side, never together on same side of car. Hope this helps.
Oct 02, 2009 | Kicker KX400.1 Car Audio Amplifier
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
Kicker dx 350 amp
Remove amp from vehicle, connect Directly to Battery, then short REM line to Ground, see if amp comes out of "protect" If it does, you have either a short or a bad connection on your power wires between amp and battery, If testing amp directly to battery and it doesnt come out of protect, it meens you fried the amp and likely your problem is wiring between the amp and the speakers, or even the speakers themselves (shorted) .. If you Drive your speakers hard enough they can overheat and short out after a short blast... anywhere from 10seconds to 45 mins.. depends on many variables.
Jan 25, 2009 | Kicker DX350 Car Audio Amplifier
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Protection light is on
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 26, 2007 | Kicker KX600.1 Car Audio Amplifier
Car Audio & Video Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
