Question about Ruud UBHC Air Conditioner
Blower motor need indoor blower motor model # UBHA - 17J11NFDAI Motor HP./F.L.A. 1/4 2.0 Volts 208-240 VAC
pierre1811
  • 144 Answers
SOURCE: Not sure what blower motor to get for my furnace
The real relevant info is 1/2 hp, 1050 rpm, 115 vac, 1/2 inch shaft. Bring that info to any HVAC supply, any appliance parts, Graingers etc. and they should be able to match it up. I just went to the Graingers site and you can order one for $87.50 plus shipping. lease give me a good rating for getting this info for you. Thanks.
Posted on Jan 30, 2009
  • 56 Answers
SOURCE: ruud silhouette #UHDG-07EAUER won't heat house
Cleaning the flame sensor has nothing to do with blower motor not turning on. You either one of the following problems 1 bad cap for motor. 2 bad motor. 3 bad limit on blower housing or 4 a bad board. You will need a volt meter to check for these problems. Try seeing if the fans runs with unit of and fan switch turned to on. Also does motor hummmm. Is motor cage free ( can check by manually turning) If motor doesnt humm and the cage is free wheeling then you will need to find out if you have power going to the motor. If you find out that you do then you will need to change blower motor. If you do not have power then you will need to check limit with continuity tester on volt meter. If that checks fine only 1 thing can be wrong and that is the board.
Posted on Feb 16, 2009
bobicehouse
  • 1524 Answers
SOURCE: i need to change blower motor
See if you can move it freely by hand. If so, change the fan capacitor. If tight, try oiling the motor.
Posted on May 01, 2009
farfield
  • 462 Answers
SOURCE: Need original blower motor and cap. specs for Ruud Deluxe 90+
The motor specs can change from time to time depending on what the manufacturer has in mind.
If it has locked up check first and make sure the squirrel cage fan has not moved and is binding on the housing.
If it is clear to turn and wont turn,, the bearings must be bad, and this is probably NOT a problem with the motor being "wrong". Its just the way things are made.
Contact a RUUD distributor for the specs you request.
Posted on Jul 10, 2009
  • 415 Answers
SOURCE: RUUD UBHA-14 J11SFJA air handler. The fan (blower) doesn?t runs
Absolutely, however, you want to properly diagnose the reason why the fan is not running. It could be a less expensive part than the fan motor itself.
First, check to see if you have the proper voltage going to the motor. I believe your motor requires 240volts ac. If you do not have 240 volts, you have a control problem.......either the thermostat is failing to close R & G or your blower relay may have failed to close the contacts necessary for your fan to operate.
If you have the voltage, then you want try spinning the blower wheel with your hand. Does it spin freely? Is the motor warm/hot? If so, turn everything off for an hour or so. As soon as your energize it, try spinning the motor with your hand again.....if it spins freely with no resistance and then starts running by itself, the problem is the run capacitor (approx $20.00 depending on where you purchase it from). If there is resistance when you try to spin it, the problem is most likely with the bearings and you will need to replace the motor.......if you have to replace the motor, go ahead and replace the capacitor also, making sure it is properly "matched" with your new motor.
I hope you find this to be very helpful to you, moving forward. :-)
Posted on Mar 28, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Keeps shutting down and E-1 appears
You don't mention brand name and type of unit. But E-1 means for 3 problems.
1. Indoor room sensor defective replace it. 2. Indoor blower motor mechanism blocked. Check and rectify by replacing bearing or motor. 3. No power sensing to Blower motor from your PCB. If yes, replace PCB.Helpful?
Jan 18, 2011 | Heating & Cooling
Mar 28, 2010 | Ruud Handler Air Conditioner
Im looking for a parts list and manual for an american standard system as well as an indoor blower motor. model # wcc030f100bb
Instead of looking for an OEM motor which can cost an insane amount of money...
try taking the information off the motor itself and taking it to a part supply house or motor shop. i.e. an 875RPM 1/4 HP 208 V 1 PH motor with a 1/2" shaft.
Maybe taking the motor itself to the parts house or motor shop will get you further than internet searching a blower motor part number. These systems are designed so that universal parts can be put back in place....at least most of them.
Feb 07, 2010 | American Standard Heating & Cooling
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Ruud UBHC Air Conditioner Logo
66 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
