Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
FDW60 Hello, I have a Hotpoint FDW60 dishwasher. It seems to have the usual quality issues but the actual problem is different to most I see on here. The machine has only been used about 20 times, but yesterday the following happened, I loaded and selected intencive program, when I pressed start the machine made a shriek/chipping sound, it seemed to run for about 5 seconds then stopped with the power and prewash lights flashing erraticly for about 3 seconds then was totaly dead, no power light or anything, just about an inch of water in bottom. After 10 mins or so the power light will come back on if I keep turning it on and off but next time I try to start it just the same. Any ideas? Thanks Tom
  • 641 Answers
Tom, If your dishwasher is still under warranty, best thing will be to contact Hotpoint's service center for repair the problem.
Posted on Aug 30, 2007
SOURCE:
I am looking for service manual for my hotpoint dishwasher
google search make model number pdf and see what it comes up with...hope this helps if not ..send info here and ill try to find for you
Jan 02, 2015 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 DishwasherTablet does not dissolve
our HOTPOINT FDW60 is not working right?
the tablet is not disolving inside right how will i fix it?
Feb 07, 2013 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius FDW60 Machine stops halfway through its cycle & the "fast" & "delicate" cycle LED's are flashing - what is my problem?
This sounds like the heater is not energising usually means the heater has failedalthough a blocked or sticking pressure switch will cause the same problem
Apr 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My fdw60 hotpoint dishwasher seems to start then the fast light and the delicate light flash and it stops. Please help.
Have you tried cleaning out the filters in the base of the machine? Also make sure there is no bits in the filter sump. Then give it a clean using a dishwasher cleaner.
Nov 10, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 dishwasher, heater not heating water or drying.
If the heater is ok and the wiring is also not burnt out, then the fault will likely be the heater relay on the pcb. (Which means usually replacing the board).
Feb 25, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Door won't shut Hotpoint FDW60
It maybe installed to high and if you lower the legs to lower the D/W you should be able to see that it will fix your problem.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
223 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
