Question about PSC QuickScan QS200 (07307-01100-0010) Handheld
RESETEAR MESSAGE PHONE QS200 - PSC QuickScan QS200 (07307-01100-0010) Handheld
Como resetear korg..
para resetear el pa50sd
Please see "Loading Korg Pa50SD's Operating System" below for
instructions on how to load the operating system.
Sep 12, 2013 | Korg Pa50 Professional Arranger Keyboard...
Error message - paper jam in exit path but no paper jammed there.
esto pasa por qan mandado a resetear y no asiodo el reset indicado
ya te dejop un link para q descarges eld reseteador
Oct 04, 2011 | Samsung SCX 4600 multifunction Laser...
.comnecesito resetear la impresora como
No es posible resetear esa impresora. Desconectarla por 5 minutos reinstala los drivers en tu PC. Eso deberia "resetearla"
Aug 26, 2011 | Epson Stylus C42SX InkJet Printer
The printer continue to display yellow light for colour ink catridge even after refill
Each cartridge comes with a chip which indicates whether the cartridge is full or empty. By refilling the cartridge the chip cannot be reset. If you cannot get past this message on the printer you may need to buy a brand new cartridge that is not refilled.
May 28, 2010 | HP DeskJet 920c InkJet Printer
Nokia 1112 factory reset code i forget the original code
If you want to know the preset code on your mode, - it's 12345
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Nokia 1112 Cellular Phone
Necesito resetear la motherboard
Hola,
Bueno, lo unico que puedes resetear el el BIOS. Hay tres maneras de hacerlo.
  1. Prende la computadora, entra al BIOS y escoje "load defaults"
  2. Sacar la bateria redonda de la placa madre
  3. cerca de la bateria por lo general hay un "jumper" para cruzar dos patitas y resetear el BIOS
Aug 03, 2009 | Foxconn 6627MA-RS2H Motherboard
Reset access point motorola symbol ap 5131
Just pull the power supply plug out for thirty seconds. It works for me. You are correct I don't ever use the reset button. In fact the techs at Verizon told me to just pull the plug out.
Hope this is what you wanted,
Please leave rating...thank you
May 06, 2009 | Computers & Internet
Se me olvido la Clave del router
Si te olvidaste la clave del router, proba usando la original de fabrica del router:
D-Link
usa esta direccion de acceso http://192.168.0.1
- user=admin
password= (sin password, en blanco, solo pulsa enter)
(generalmente son (admin, password) y mira que pasa (si es que no la cambiaste)
Al resetear el router volvera a su configuracion inicial y perderas la informacion que tenia configurada. Antes de resetear podes tirar un ip config saber tus ip adresses.
Ahoras si te olvidaste la clave de acceso a tu network, podes obtenerla con cualquier aplicacion de password recovery.
Oct 24, 2008 | D-Link DI-808HV Router (280006OB)
Mi ipaq no arranca
amigo tu problema es sencillo pones una agujita en et REST detras de ru Ipaq y al mismo tiempo enciendes sin quitar la aguja 3 segundos luigo quita la t enciende la bestia volvera aa arrancar
Oct 12, 2007 | HP iPAQ RX3715 Pocket PC
PSC QuickScan QS200 (07307-01100-0010) Handheld Logo
79 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Sardar Yasir
Sardar Yasir
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
