Question about Boating
Raymarine A65 gps sensor
I have the Ray marine A65, the R12 GPS sensor no longer works.. & they no longer make this part. I called the Tech Dept. a at Ray marine & they said I could use the NMEA 8013/ Digital Yacht/105. I ordered it from defender and it doesn't come with the connector (5prong cable). None of the cable colors match, for splicing. Is there any inside info out there?
2 Suggested Answers
SOURCE: a65 Raymarine combo gps plotter fishfinder
changes.
Posted on Jan 09, 2009
Need power supply cable raytheon v850
Anything Raytheon is going to be tough now since it is no longer supported by Raymarine. You may still be best to start by calling Raymarine's tech dept to see what they say. If no luck, your next best try is probably EbaY.
Raymarine Tech support 18005395539
Aug 04, 2009 | Raymarine B60 12 Tilted Element Transducer...
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
A-65 screen has fine scratches/clouds
My Raymarine A65 was so bad in daylight I could not read the screen. Used Never Dull polish from ACE hardware, similar to Brasso, and it took every scratch and cloudy mark off the screen. The can documentation includes glass as one of the items it?s safe to use on. Looks new again, Good Luck, Paul
Apr 08, 2009 | Raymarine A65 Combo GPS...
A65 Raymarine combo gps plotter fishfinder
your local marina should be able to tell you and they most likely are a dealer for seadog or diversified which will sell your parts just give them your model or just take the unit in with you
Oct 16, 2008 | Garmin 340c Fish Finder Dual Frequency...
Raymarine Ray 240 usa model
You cannot just reprogram your Raymarine to european standard.
This radio has been built and is licenced for using with USA frequency, in Europe his use will be limited to lower bands with no modification.
To be fully adapted to higher bands, the radio must be taken apart, and you need to bridge a contact on the main board.
The use of the radio after modifacion won't be legal in Europe.
Oct 03, 2008 | Raymarine Ray 240 Modular Vhf System
Raymarine A-65 unable to find satalites
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
May 17, 2008 | Raymarine A65 Combo GPS...
RAYMARINE A65 COMPLETE FAILURE
Was the engine running when it shut off? How was the voltage at the time it failed? The A65 will shut down if the voltage drops below 11.2 volts.
Another common cause would be corrosion on the plug where it plugs into the back of the display, or the terminal connectors that attach it to the boat's power supply.
It could also be a bad crimp on the terminal connectors. Make sure connectors are the right size for the wire and that they are marine grade, such as Ancor brand connectors. I also recommend heat shrink style connectors,
I have not heard of any software issues for that model so I am betting it's a wiring issue. However, there is an update available from Raymarine. There were changes made to the WAAS satellites and the update helps it recognize the new satellites. You can download it for free from Raymarine. Copy it onto a blank CF card and plug it into the card slot on your GPS. When you turn the unit on it will prompt you on how to proceed with the update. It will fix any known software gliches at the same time.
I hope this answer helps. Please reply if you have any questions about my response.
Feb 25, 2008 | Raymarine A65 Combo GPS...
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
Raymarine A65
When the engine starts, there is a voltage drop as the starters crank, followed by a power surge as the alternators kick in and the voltage comes back up.
Ferrites are only there to prevent RF (Radio Wave) interference from other onboard devices.
You should either:
-add an isolated battery to the boat to service only your electronics. That way it is unaffected by the starters.
-There are several devices on the market like Newmar Power's "Start-Gurad" that automatically switch electronics to backup power during engine start. They work great and the electronics don't skip a beat.
Nov 16, 2007 | Raymarine A65 Combo GPS...
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
