Question about Measuring Tools & Sensors
Strait line accuscan stud finder - Measuring Tools & Sensors
2 Suggested Answers
  • 157 Answers
SOURCE: how do you know when the strait line laser level
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Posted on Mar 29, 2011
How replace battery in stud finder
It is very easy. Open battery compartment at the back and remove old battery and put new one in.
If you get stuck you can download manual from here:
Jul 01, 2012 | Strait-Line Intersect Laser Level With...
Performance Tool Digital Tape Measure W5746
http://www.irwin.com/uploads/documents/30_intersect_laser_level.pdf
If that is not the correct one, check here:
Jan 29, 2012 | Strait-Line Intersect Laser Level With...
I can't find my user guide, What settings do I use for stud finder?
Hello. The instructions can vary from model to model. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
Mar 27, 2011 | Strait-Line Intersect Laser Level With...
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Sep 17, 2010 | Garden
How do i find a stud with the stud finder
Aug 18, 2010 | Strait-Line Intersect Laser Level With...
How do you know when the strait line laser level and stud finder is on a stud
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
Strait-line
Yes. The lights represents the stud. As you move it over each light lights up.
May 30, 2010 | Strait-Line Strait Line 6041706 Stud...
How do I know when i am on the stud
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
May 07, 2010 | Strait-Line Strait Line 6041706 Stud...
Measuring Tools & Sensors Logo
137 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
