Question about HP iPAQ RX3715 Pocket PC
IPAQ Rx 3715 Internet settings~ conectivity problem
I'm having problems connecting to the internet with this PDA using WIFI. Any help!? Not real famillar with the settings needed for the correct connections. I see my avail network and others.. but not able to connect. it says "cannot connect with current connection settings" Help Thanks ~ Robin
    Problem Solver:
  • 15 Answers
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Posted on Mar 01, 2008
SOURCE:
My HP Ipaq pocket pc h5450 with windows mobile 2003 want i connect to the internet i have type the key of my router in it says that it has been conected but if i got to the internet exploren and go to a...
set both ends to WEP, most cant do WPA/1 or 2. this toy PDA
or ask at HP ,fixya is not HP, ok.?
if you google you find and old manual, do that yet or just guessing how to use it?
https://h30434.www3.hp.com/
Dec 09, 2017 | HP iPAQ H5450 Pocket PC
I have an hp ipaq the model is hx2190 and i have no clue how to get a wifi internet conection?
Via the PC your IPAQ talks to your PC / Phone by Bluetooth and shares the internet connection it does not connect direct to the internet
Jan 20, 2011 | HP iPAQ hx2190 Pocket PC
Can i get on the internet without using a modem card?
Your PDA doesn't have a inbuilt modem or wifi, so you can't use the Internet without a modem card.
Here are the specifications of your iPAQ:
http://reviews.cnet.com/pdas/hp-ipaq-pocket-pc/4507-3127_7-30422067.html
Jan 14, 2011 | HP iPAQ H1945 Pocket PC
I am trying to get email access. I am not able to get my email even though my PDA says that it is connecting to my Wi-Fi
First you have to ensure that the problem is not from the internet connection. Try using the PDA and the same wireless connection to open a different site which is different from the email provider. If the other site opens then you are sure that the problem is from either the phone or the email service provider.
On the other hand if it does not open then this means that the recommended settings which are expected for the PDA to work with the wifi have not been properly set to give the PDA internet access. The device might be connected to the wifi but not connected to access the internet from the device. Try setting up the PDA and this time take care of the settings.
Hope this solution has been helpful?
Jan 08, 2011 | HP iPAQ H5550 Pocket PC
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
HP iPAQ 112 PDA CDMA Phone
yet another useless Ipaq, relic.
ok, what now.?
no it cant. it's a PDA , it is not a phone.
it can do wifi, if lucky most cant.
wifi is an option sold new.... so can be missing.
even with it most modern routers block it.
why not just buy and old smart phone.
use that.
avoid PDA like the plague.
Feb 13, 2018 | HP iPAQ 110 Pocket PC
How do i connect my ipaq PDA to a wireless network
This may help - from my 3715
start, wireless, press wifi button to turn ON (yellow or green)
Green = connected
settings
select the wireless from the list and select the Network Key tab
Make these details match your access point
for a unsecured point (public) make authentication = open and datad encryption = disabled
pos back any questions to resolve fully
If it does not connect then the wireless has encryption so you need to set the pda encryption to be the same
start, wireless, setup, selet from list,
Jul 05, 2008 | Computers & Internet
IPAQ rx3100 series
old mixed with the new. this toy PDA is 14 year old today.
do you own the router or the ISP or phone company?
you mean wifi, wireless has many forms!
the new router is using security that the old IPAQ cant do.
you have 2 choices
1: change THE ROUTER to weak encryption (and risk all other computers using it)
2: or get rid of the IPAQ, they are junk now. old and obsolete and no support, HP retired them, as legacy status.
if your read the manual for the IPAQ, it clearly shows its limits.
lots.
spec. 802.11b
WEP 64/128-bitcompliant to IEEE 802.11Compliant to 802.1X (EAP-TLS,PEAP)WPA
see the lack of WPA2?
if you set up your router to be wpa2 only as most folks do for
max security and ISP do,, no IPAQ like this works.
to others reading the battery just pops out on this newer model
then see a white sticker that sticker shows if your PDA
was opted with wifi and or bluetooth, there.
on the pda menus , labeled WIFI
make sure all off is not set to on, on main screen
click settings.
chapter 7 in the manual covers this.
turn it on
turn off ipaq wifi power saving mode, or it will fail.
the 3 lines in read below
must match your routers setting.
for example min router has WEP turned off so i cant get hacked.
wep is no longer secure.
pda-p0syz24ik43idjojxsw3jniu-4-0.jpg https://www.manualslib.com/download/850185/Hp-Ipaq-Rx3000-Series.html
it can connect
but the rules are very restrictedhttps://www.manualslib.com/download/850185/Hp-Ipaq-Rx3000-Series.htmldu,
Feb 12, 2018 | HP iPAQ RX3100 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Connect to the Internet
There are many things to look at when setting up WI-FI to work with your iPAQ. Here is a good link that walks you through the WI-FI setup, with helpful screenshots. Its a good place to start, hope it helps! http://wifi.aximsite.com
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
383 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
