Question about Home
Model# F1AA4535BNV My shower facet will not function, when I turn the valve, I get a small tickle of water.
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 35 Answers
SOURCE: Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Posted on Jan 12, 2009
frcs68
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
  • 659 Answers
SOURCE: no water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Posted on Apr 10, 2009
  • 145 Answers
SOURCE: moen shower valve turns on full to cold water but
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Posted on Nov 29, 2010
Water is coming into the house but isn't coming out of my facets.
A couple of things to check also:
1. I am assuming that you have checked the shut off valve that is usually inside the garage. Make sure that the valve handle is aligned with the pipe, if not turn the handle so it will be aligned with the pipe.
2. Toilet, flush it and see if the tank is filled up again. if the tank fills up right away, then your problem will be in the faucets.
3. Test your shower. If water comes out of the shower heads, then your problem might be in the faucets.
4. How old id the house? if the faucets are not being used regular basis, your seals in the faucets might have hardened up and sticking.
5. hope I have given you some help in trouble shooting your water problem. Good luck.
Mar 13, 2017 | Plumbing
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
How do I remove the cold water handle?
You will need a set of std allan wrenchs.There should be a small set screw behind the portion of the handle that you grab onto .Its not nessisary to remove it,only loosen it.Then gentlypull and wiggle the handle ,it should come right off.
Dec 11, 2009 | Delta & Single Handle Shower Faucet
Warmer water
take handle off and turn stem 180 degrees and put handle back on,...should be fixed.
Nov 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
My mixet bathtub faucet only produces hot water
single lever facets do this all the time
flip the facet leverover
ie remove lever and spin the center gut 180 degrees re install the lever and wala you have hot and cold water
if not check your supplu lines dont have a kink in them or they are not pluged
remove hot supply line and open feed valve over a bucket no water ?
turn on the other shut off valve
remove cold line over bucket open valve you have water then you have a bad faucet
return it then install a glacier bay faucet they are cheep and they work well
Jul 25, 2009 | Home
Bath tube plumbing is making vibrating sound then shutting off
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Dec 11, 2008 | Plumbing
Home Logo
102 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
