Question about Amana Heating & Cooling
Rhe36a2a amana outside unit will not come on at times
Installing an Amana ptc153g35c unit. Have question about grille installation and drainage for outside
You should have h=got full installation instructions with it although this model seems to be discontinued. Grill installation should be straightforward. The drain to outside is normally 3/8 or half inch pipe and is required for the defrost cycle and to catch condensation..
Nov 01, 2016 | Amana Heating & Cooling
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
My Amana PTAC allows outside air to come through the entire unit (everywhere). I think that maybe the outside air vent, which is closed) is not secure. Would there be a problem with screwing it shut w
If you can get to the fresh air vent, and it is open, plug it by any means necessary, as long as it's safe. It will not affect the overall operation of the unit.
Oct 22, 2017 | Heating & Cooling
Hisense reset
The outside vent must be OPEN to allow the appliance to get the needed air. In the heating mode of a heat pump, the outdoor coil becomes the condenser. Open the outside vent!
Nov 25, 2013 | Amana Heating & Cooling
Amana central air conditioner unit rce60a2a.fan not spinning.thermostat fine and breakers on.buzzing noise on outside unit.any reset buttons or any advice?thanks, ryan
I would say the Capacitor outside has failed and the bussizng would be the contactor trying to start the unit. If you are able to pull the capacitor and go pick one up at an electric motor place then that would be the cheapest way and they could test it first
Aug 20, 2010 | Amana Heating & Cooling
AC not blowing cold air
Remove the outside fuse from the unit that is not cooling... remove all the sheet metal from around the outside unit.. see if there is a lot of grass/weeds/ bird nests, or other material in the coils.. if there is... use a high pressure hose to clean the coils completely!!!!! (I had this done to mine...worked much better!!)..if this doesn't help,, I am afraid it might be time for some freon... and yes..its $$$$...
Aug 11, 2017 | Amana Heating & Cooling
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Jan 18, 2009 | Amana PTH123B25AJ Heat Pump Air...
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
