Question about Freezers
Frigidaire fphc2399kf1 The freezer is building up ice on the bottom shelf and it is leaking out the bottom of the freezer door. The drawers in the refrigerator freeze occasionally too.
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
hotuna
  • 288 Answers
SOURCE: fridge freezer.
I had to look up where you are from. Being the U.K. you mean 16 celsius, right? If the problem began after you removed the boxes, I don't think its a circulation problem. The ice build up on the inside, and the freezer being good but not the fridge, makes me think the defrost isn't working. I can help you check the controls for this, but without a volt/ohm meter you should call someone.
Posted on Dec 31, 2007
22yooper
  • 828 Answers
SOURCE: maytag side by side freezer leaking water and icing in bottom
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
Posted on May 17, 2008
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
aborcass
  • 2651 Answers
SOURCE: Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Posted on Jan 14, 2009
Frigidaire bottom freezer spills ice when opened and I can't shut the drawer til I fish the ice cubes out.
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Mar 02, 2018 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Jan 30, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
What can I do to get rid of frost build-up (more than 8" long & 1/2" Deep) on my NEW FROST FREE FRIGIDAIRE FREEZER GLFU2067F?
contact 1-888-77-lowes if you havent done this call, have them create a case file on this, tell the person that you talk to that if you try this solve and it dont fix the issue I want a new machine if they agree to this do the door replacement if they don't take it back to lowes
Mar 25, 2008 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezers Logo
35 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
